big muff pi noise reduction mod
- pinkjimiphoton
- my favorite amplifier: my own, a redesigned princeton
- Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
there's videos that totally suck of about 90 of 'em here:
http://youtube.com/666pinkster
gimme a like: http://facebook.com/pinkjimiphotonrocks - Location: new world order land (formerly la-la land)
- Has thanked: 358 times
- Been thanked: 476 times
- Contact:
no idea how this works or why... but if you parallel the bat41 at d4 on the board with a 1n34a oriented the same, it cuts out most of the "ocean" with a big muff pi.
you can still get all the same sounds out of it, but without the noise. seriously. try this and let me know if it works for you!!
did it on a reissue nyc bmp. made an astounding differnce.
Slava Ukraini!
Slava Ukraini!
Hi Jimmy,
I had to post to say thanks for this tip.
It works very well.
Regards,
Craig.
It works very well.
Regards,
Craig.
- pinkjimiphoton
- Contact:
yah, takes out most of the noise, for sure.
any idea why it works??
Slava Ukraini!
Slava Ukraini!
- Cub
I'm going to try this the next time I'm building a Muff. Before the end of the year, I hope, but probably somewhere in January.
Thanks for sharing !
Muffs are noisy beasts by nature, every bit of reduction is welcome.
- pinkjimiphoton
- Contact:
it does sacrifice a tiny bit of balls, but unless you run everything dimed hard to notice.
Slava Ukraini!
Slava Ukraini!
- pinkjimiphoton
- Contact:
yah, but why does it work in just that *one* spot? i tried it elsewhere, and no dice. on two bmp's and both the same... weird. that one position makes a big diff.
Slava Ukraini!
Slava Ukraini!
- astrobass
D4 is on Q3, right? What about running the ge diode parallel to the other diode on Q3 instead? No dice?
If that doesn't work, I'll be puzzled. Right now I'd guess that it works by reducing the signal hitting Q4 by just enough. But it might be something more subtle that I'm not knowledgable enough to guess at.
- pinkjimiphoton
- Contact:
if memory serves, it was only that one diode that worked out like that. i don't remember which one without re-reading the thread, but i did try it on the others and it did not have the same effect. did it on a behringer vd1 too, worked there the same. there's just enough room in them to mess with the diodes some and replace 'em with real ones.
Slava Ukraini!
Slava Ukraini!
- pinkjimiphoton
- Contact:
so...... verdict?
Slava Ukraini!
Slava Ukraini!
- Blend
Wow Jimmy , tried with a AA118 germanium and works great, in my opinion lowers the gain of the ultra big muff and her turbulent noise. it is however necessary to increase the resistance of the sustain minimum that would otherwise be dark in tone. Connected to a momentary switch can generate two different frequencies of feedback Morello style.posting.php?mode=reply&f=28&t=23085#
- pinkjimiphoton
- Contact:
cool!! thanks for the verification!
it DOES lower the gain slightly, but i think in a good way... just kinda takes some of the noise out.
only seems to matter on that one diode. what the fuck?!?!?!? lol
Slava Ukraini!
Slava Ukraini!
- Blend
- pinkjimiphoton
- Contact:
you got 4 diodes on any big muff board. try it until ya find the one that works. that's the one ya leave it on.
but it's gotta be germanium. si don't work!
Slava Ukraini!
Slava Ukraini!
- pinkjimiphoton
- Contact:
cool jose!! just look at a schematic, whatever d4 is is what i found worked in all three muffs i tried including the behringer copy.
Slava Ukraini!
Slava Ukraini!
