Reducing voltage from 12V to 9V on power supply
Hi all,
I have a T-Rex Fuel Tank Classic power supply that delivers 3 x 500 mA from three sections, 9V DC, 12V DC and 12V AC. I have exhausted the capacity of the 9V outlets (I only buy 9V pedals as a matter of principle), and so I wonder if there is a simple voltage reducing circuit that I can either put inside, or piggy-back on top of the Fuel Tank. I imagine T-Rex would just ignore me if I sent such a request to their customer support (or at best they would recommend purchasing another T-Rex product). My electronics knowledge is not exactly impressive, but I figure it should be a fairly simple deal to reduce the voltage. Is it just a matter or adding a resistor or two? I just need a simple schematic and parts list. Can anyone help? PS. I know a lot of 9V pedals can handle 12V too, but I don't want to risk anything, so I'd prefer to get the voltage down.
- alexradium
many pedals work just as well with 12Vdc,mostly dynamics,you have to check out the specs in manuals to find out any problem with higher voltages.Super Locrian wrote:Hi all,
Anyway,you can get 9Vdc easily with a 7809 voltage regulator and 4 caps from the 12Vdc output.
You can do the same with the 12Vac,just inserting a 4 diode bridge rectifier between the output and the aforementioned circuit.(more dissipated energy so you need a heatsink.)
Its everywhere,check out any site like Geofex or General guitar gadgets or Tonepad for complete projects
- tip142
If you haven't lying around the 7809,simply put for 1n4.... in series and you drop from 12v to 9,2 v quite happily and satisfactory.alexradium wrote:many pedals work just as well with 12Vdc,mostly dynamics,you have to check out the specs in manuals to find out any problem with higher voltages.Super Locrian wrote:Hi all,
- deltafred
- Opamp Operator
The forward voltage drop of a 1N400x is somewhere around 0.7v so you would need 4 or 5 in series to drop around 3v.tip142 wrote:If you haven't lying around the 7809,simply put for 1n4.... in series and you drop from 12v to 9,2 v quite happily and satisfactory.
New 9v batteries are usually a bit higher, around 9.6v so 4 should be ok but it depends how accurate your 12v supply is. If you are worried then start off with 5 and measure the pedal voltage. Take one out if it is below 9v, add another if it is over 9.6V. I would add a 100uF 16v electrolytic in parallel with 0.1 disc ceramic decoupling capacitors across the 9v output.
Not the most elegant of solutions but it will work.
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
I've actually seen some 9V batteries measure something like about 10V when measured by a multimeter....
- deltafred
- Opamp Operator
You can but you waste more power because you need a certain current through the zener for it to operate properly (and 9v batteries don't have a lot to waste).bcalla44 wrote:Can't you do it with a 9.1 v zener diode with a resistor in series?
With the 1N400x you only draw the current the pedal draws, a zener needs a few milliamps extra.
- mictester
You can, but the resistor will just be wasting energy as heat! Also, zener diodes tend to be a bit noisy.bcalla44 wrote:Can't you do it with a 9.1 v zener diode with a resistor in series?
