Earthquaker Devices - Bit Commander  [traced]
gaffled
Post by gaffled »
I had only limited time with one and was able to take this pic and write down all the component values. I took a pic of the values I wrote down, just ask if some cant be seen. I wish I could have taken out the pcb and got a trace side pic but it wasn't my pedal and they wouldn't let me. Maybe someone else can get a trace side photo or from the components piece together how it works.
---dead links removed----
ieatyouforbreakfast
Post by ieatyouforbreakfast »
Just bought the pedal. Anyone at all interested in gutshots?
What I remember seeing in there is a transformer, two LM386s and some other cool stuff.
smurfberry
Has thanked: 20 times
Been thanked: 5 times
Post by smurfberry »
The traces are covered by the white laquer on the board, on both sides. The circuit can still be traced, but it's a bit hard to do from just photos.
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
So maybe it is an input buffer (left opamp of TL072) which splits the signal to the octave up generated by LM386, transformer and diodes like Bob's Octavia below, with a parallel send to the CD4040 (is it? can't read the marking well enough) for the one and two octaves below like the Robot devil, then back to the other half of the TL072 for an output mixer.
I'm guessing the 386 has it's output tapped before the transformer to the B100k pot to provide the fuzzy "base" guitar (and maybe the send to the 4040 comes from here too), and I assume the filter control is just the 5k pot and the red cap to ground on the output for treble roll-off, just before the A100k level pot. Quite a cool little package, a bit like a dirty, much lower parts count version of the excellent Pearl OC-07 Octaver.
Robot Devil two octaves down -
https://www.freestompboxes.org/viewtopic ... obot+devil
smurfberry
The CMOS IC is CD4024BE, used in Slacktave and 4ms Nocto Loco
kroaton
Post by kroaton »
Here's a better gut shot I found (still useless)
I've been messing around on the breadboard using the values I transcribed from the gut-shot and Nocentelli's ideas and it's getting quite close to the original, though I'm starting to think that there are better circuits out there that do the same thing.
azrael
Has thanked: 35 times
Been thanked: 87 times
Post by azrael »
I'll try and open up mine sometime soon. Maybe I won't have a white silkscreen on it.
Nocentelli
Component-labelled gunshot and schematic at tagboardeffects.blogspot.co.UK
http://guitar-fx-layouts.42897.x6.nabbl ... 802579-237
I've posted links to the images, I can't seem to link to the thread containing them or subsequent discussion directly, hope IvIark doesn't mind.
I wonder if the transformer and 4024 could be replaced with the bjt phase-splitter from the Green ringer and 4040? (i have the latter but not the former)
tabbycat
Post by tabbycat »
link to the post at gfx here...
http://guitar-fx-layouts.42897.x6.nabbl ... 22775.html
unverified vero layout recently added.
storyboardist
Has thanked: 81 times
Been thanked: 224 times
Post by storyboardist »
Here's a perf and PCB layout of the Bit Commander. I used the same schematic TabbyCat posted above (which I believe is verified).
kerbang
Post by kerbang »
Can one just use the final two stages of a roger mayer octavia in place of the transformer? Cuts the cost a bit...
Visualdistortion
my favorite amplifier: Laney
Completed builds: Many...
Been thanked: 23 times
Post by Visualdistortion »
Does the chassis of the transformer need to be grounded? thanks
I wanna make it
I wanna make it wit chu
(again and again and again)
French... sorry ;)
kerbang
Post by kerbang »
kerbang wrote:Can one just use the final two stages of a roger mayer octavia in place of the transformer? Cuts the cost a bit...
Short answer no.
Long answer:
I'm no expert but I tried a few circuit configurations and in the end I gave up and tried throwing my madbeanpedals slambox in front of the octave stage of an RM octavia. And well, it works for me. Haven't socketed diodes yet so on the off chance someone actually wants to try this for some reason.. yeah do that. I used Germ ones off the bat so who knows what 4148 sounds like. D3 is just polarity protection. Oh and I went with a 47n instead of 100n. Maybe I should have gone lower.. Suggestions for improvements would benefit me. Put an LM386 with clipping before it and tell me if it makes an amazing IC fuzz octavia.
FausterCraster
Has thanked: 17 times
Post by FausterCraster »
Schematic link is no longer working.
Anyone has the schematic picture pls ?
Ichabod_Crane
Has thanked: 58 times
Been thanked: 31 times
Post by Ichabod_Crane »
Porpoise Head
Post by Porpoise Head »
Hi all,
This is my first post here. Does anyone still have the schematic for the Bit Commander? The links are dead. Thanks in advance!
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
Porpoise Head wrote: 10 Jan 2023, 20:44 Hi all,
https://docs.pedalpcb.com/project/CaptainBit.pdf
https://pcbguitarmania.com/wp-content/u ... g-Docs.pdf
https://pcbguitarmania.com/wp-content/u ... der-v2.pdf
