Ready to use, easy connect.
Dimensions (size PCB with components): 2,1 x 2,5 x 0,4 cm
Weigh no more than 20 g
Power supply: 9V
Current consumption: not more than 10-11 mA.
Impedance: 50k (also available at the user's discretion values 10k, 100k)
Min impedance (50k): 1,8 k
Max impedance (50k): 47,8 k
Number of stages: 50
LED Display error rate (analog mode): 20%
LED Display error rate (tap mode): 10%
Synchronized delay time: 60-580 ms.
How to connect: http://v2.piodfx.com/pdf/Tap-Me-Pot-wiring-diagram.pdf
How to use:
Set the tempo by pressing the Tap button twice, the module will recognize the rhythm and install the appropriate amount of delay. To quickly reset the delay in starting the minimum position, press and hold the Tap button for 2 seconds. At any time, you can turn the mechanical potentiometer, which would set a new value in the manual, analog mode.
LED Indications:
Blinking LEDs for normal operation, the rate of job successfully. LED on: error indication, set the tempo again.
To order:
please contact: piodfx(dog)@gmail(dot)com PayPal accept.
Tap Me Pot - 20$
ready to use module, but with out switch and a potentiometer. World wide shipping + 3$
Tap Me Pot (Full package) - 25$
Ready to use module, with switch and a potentiometer. World wide shipping + 5$
Delivery time around the world: 1 - 2 weeks. A tracking number is provided.
Sending unit from Ukraine. Maybe after a while I will give a few modules for my friend in the United States, if it is convenient for anyone either.
Thank you for your attention.
