I've run into a spot of trouble and am struggling to find a way to resolve it.
Basically I have a Fuzz War and OCD in one box with a switch to select between circuits and a main bypass switch, the problem occurs when the Fuzz War is selected I get a high pitched oscillation from the OCD (I presume it's the OCD as the oscillation stopped when I pulled the IC out to kill the circuit). The squeal is there albeit quietly when the pedal is bypassed and increases in volume considerably when the pedal is activated. When the OCD is selected there is no oscillation, everything fine. The Fuzz War works fine when selected but as soon as you stop playing you hear the oscillation.
This is how I have it wired up currently;
Any ideas why I'm getting the oscillation from the OCD? It only happens when both circuits are wired to the selector 3PDT, both work fine when wired independently.
I have tried wiring the bypass switch to ground the PCB input on bypass, PCB output on bypass and also neither, got the same oscillation problem with each method. Have also tried wiring all the grounds to input among various other ground wiring combinations and just can't get rid of it.
I'm at a loss now, any advice would be greatly appreciated!
Graham
