Lumpy's 73 Boost
- mmolteratx
- Degoop Doctor
Here's a schem, traced from the pics, not the vero layouts posted.
- '73 Boost.png (9.91 KiB) Viewed 1914 times
- beedotman
- mmolteratx
- Degoop Doctor
Oh, and just a heads up, the BAT46 is not in the original, I just figured any pedal should have at least basic reverse polarity protection.
- my favorite amplifier: Orange
- Completed builds: Keeley Katana Boost
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Hornby Skewes Treble Booster
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
HAO Rust Driver - Has thanked: 7 times
- Been thanked: 13 times
- Silver Blues
Just thought I'd follow over here and reiterate that that empty column (column N) can be removed for a 14x11 board.
I forgot to shrink it after I was done.
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
I had a play about on the breadboard, and a 'fat pot' works quite nicely, I just replaced the 680n cap with a 22uf electro, and replaced the switch with a 2k pot.zosotone wrote:Nice Mbas974! Any mod for this model?
- Nocentelli
The first boost JFET inverts the signal, the buffer is non-inverting so the output will stay inverted relative to the input.
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
With 22uf instead of the 680nf, what is the polarity of the electro? Its the same?Nocentelli wrote:I had a play about on the breadboard, and a 'fat pot' works quite nicely, I just replaced the 680n cap with a 22uf electro, and replaced the switch with a 2k pot.zosotone wrote:Nice Mbas974! Any mod for this model?
- Nocentelli
Well the 680n shown in that layout is non-polar, but you'd need to connect the 22uF electro with the negative stripe towards ground.
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
Ok thanks, or use a bipolar or a tantalum cap, true? I will try the vero from Silver Blues these days and check it...not yet verified right?
Skreddy Pink Flesh
Cornish LD-1
Silicon Fuzz Face
Dam Meathead
Zvex Woolly Mammoth
Zvex Hard On
Lovepedal Plexi 800
Fulltone Fatboost
Xotic EP Booster
GGG Neovibe
Done!
