http://www.geofex.com/article_folders/f ... tmatch.htm
it is really simple and fast (so I suggest it...
The lower Vgs I measured was 0,22 the higher was 0,74
Question 1 : What is the range for J201 in order to say that these are GOOD / POOR / SO-SO ?
____________________________________________________________________________________
Then I pickup the two extremes FET ( 0,22 and 0,74 )
putting 1K on source I've start biasing.
TRX 0,22 was biased with 15K resistor on drain
while 0,74 was biased with 8K2 resistor on drain
In my thought I was thinking that the 0,74 should be better then 0,22 but standing to the experiment the 0,22 can assure more gain...
Question 2 : Is there someone that can better clarify the theory behind this ?
Many thanks in advance
