PCB:Providence Stampede SOV-2 Boutique Overdrive - Interest?
rullywowr
Been thanked: 7 times
Post by rullywowr »
Hello,
I have created a layout for the Stampede SOV-2 boutique overdrive and just pulled the trigger on some boards. I wanted to see if any of you may be interested? I am thinking somewhere around $8 to $10. Here is a link to a review of this pedal:
http://www.sixstringsoul.com/stampede-sov-2-review/
It is a pretty cool pedal and I got to play around with a real one that my co-worker has for a bit. It is based around a modified Tube Screamer but the pedal (get this) uses a +9V supply stepped down to +5v then upconverted to +15v. WTF??? Pretty wasteful, so the battery life off a +9v is about 2 hours as you can expect. In my fabbed version, I took out all that silly conversion and just am going to use a charge pump to run it at +18v or around that.
Here are some mockups of what I have sent off to the fab. I call it the "Avalanche." Board corners are rounded, power at top and bottom, board mounted pots (of course!). Should have them back from the fab in 20-30 days.
Thanks for checking out my layout. =)
rullywow industries - DIY Guitar PCB Projects
http://www.rullywow.com
robinbowes
Has thanked: 17 times
Post by robinbowes »
Put me down for one.
R.
rullywowr
Post by rullywowr »
Will do! Thanks for the interest.
Philster
Post by Philster »
Me too!
Philly
rullywowr
Post by rullywowr »
Roger that. Should be 20-25 days until back from the fab. Thanks for checking it out.
robinbowes
My two boards arrived this morning.
Thanks Ben!
R.
rullywowr
Post by rullywowr »
Wow! That was really quick from usa to uk. Hope you enjoy. Let me know if you have any issues.
-Ben
Philster
Post by Philster »
Mine arrived today , too! Cheers!
Phil
andregarcia57
Has thanked: 50 times
Been thanked: 96 times
Post by andregarcia57 »
I'm interested in two PCB
