BAJA Optical Limiter revisited - rev2  [documentation]
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
Hi there
A couple of small improvements you could try:
If you use two separate resistors to the two LEDs from the op-amp output, you prevent problems caused by differences in characteristics of the LEDs. It's also worth using 1 uF electrolytics, rather than the expensive non-polarised capacitors. I know that the non-pol types are "better" for the audiophools, but if you put the electrolytics with the positive side going to the FET and the positive side to the op-amp, you won't hear the difference, and will save some space and cost!
Hope this helps!
C.
fosnal1950
Post by fosnal1950 »
Shouldn't one of these be "negative "??
Alf
mictester
Post by mictester »
Alf
Nope - the positive end of the electrolytic should be towards the op-amp in each case.
cpm
Been thanked: 50 times
Post by cpm »
While i was using the LED envelope thing for other effect i have noticed that playing on higher strings has a stronger effect than the lower end.
I just put a cap (1n) on the opamp loop to compensate, and now it seems to have a more balanced response
kierc
my favorite amplifier: Vox Cambridge 30 R Twin
Completed builds: Clyde McCoy Wah with Whipple+Red Fasel inductor switch, Fuzz Face with own layout
Post by kierc »
I'm thinking of building one of these, but not sure whether to build this second one or the first one?
I haven't read through the whole thread (sorry! :slap: ) - but what are peoples' thoughts? what are the differences other than the obvious board layout?
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
I'm going to do the 2nd one. Think ill get the same color plastic case too.
Skyline FX 2013
cpm
Post by cpm »
does the fizzy noise keep at a constant volume regardless of output volume pot? if so it may be the opamp on the sidechain is clipping and putting noise on the power lines.
ryanuk
Has thanked: 29 times
Been thanked: 28 times
Post by ryanuk »
ok - stooopid question...
Whats the difference between on compressor and limiter?
Yours... confused...
RyUK
swt
Been thanked: 13 times
Post by swt »
ok, i wanna report back because i also had problems with this one. The fizzy distortion rifing on top of the sound...i solved it by going up on the 560ohms resistor to ground on the feedback loop of the opamp. apparently i got rail distortion, maybe because i coulnd't get the right optocoupler, and use an ldr with a led. The only drawback is that i used a true bypass and the tone changed when pedal on...it makes ait a bit thinner or brighter...
coldcraft
Has thanked: 38 times
Been thanked: 84 times
Post by coldcraft »
any ideas on how to add "attack" or "release" controls?
ashtronaut
Post by ashtronaut »
hi, just wanted to check with someone about the pcb layout - it seems like the tip ring and sleeve are all connected at the input jack...this can't be right, can it? I don't have these fancy looking jacks so ...just wanted to check before i start. Bajaman?
YuGi
Been thanked: 25 times
Post by YuGi »
ashtronaut wrote:it seems like the tip ring and sleeve are all connected at the input jack...this can't be right, can it?
Those are "switching" jacks. In that way the input effect is grounded if the input jack is not inserted :wink:
ashtronaut
thanks yugi,
hmmm... so if i don't have 'switching' jacks, can i just wire in a normal jack?
YuGi
Post by YuGi »
ashtronaut wrote:thanks yugi,
Of course!
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Could I add a jack for a tuner at the point of the circuit that is labeled as "bypass output to footswitch"?
The tuner would always stay switched on. Would that influence the limiter circuit in any way?
hi rosebud11
that should work okay :wink:
roseblood11
thanx for the quick reply - my soldering iron is still hot :-)))
coldcraft
Post by coldcraft »
would anyone recommend this for acoustic guitar? does it have a fast attack or can the attack be adjusted?
phibes
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
This would probably sound awesome on acoustic guitar. I've always liked Limiters over Compressors for Acoustic and Bass.
Image Ken
meffcio
Been thanked: 14 times
Post by meffcio »
Is there any mod that makes this limiter bass-specific?
