Dr J - D55 Aerolite Compressor  [schematic]
mysticwhiskey
Has thanked: 42 times
Been thanked: 175 times
Post by mysticwhiskey »
I haven't yet fully traced the circuit, but I'm about 75% done and at this stage it is looking like it's a Boss CS-2 with a blend mod to mix the dry and compressed signal.
IC is LM13700N, FETs are J201 and transistors are 2N3904.
mysticwhiskey
Confirmed: This is a Boss CS-2 clone (using a LM13700N instead of BA662A), with adjustable blend of compressed/dry signal.
artaommahe
Has thanked: 18 times
Post by artaommahe »
So it's half of LM13700 here witout buffer and diode-bias, so can we use CA3080 here? Using less space..
perwin
Post by perwin »
I miss values of rezistors in the scheme. Could you please post them?
Also, do you have this scheme and/or pcb design available for download in format for Eagle or KiCad?
Thank you.
perwin wrote:I miss values of rezistors in the scheme. Could you please post them?
Why don't you do some of the work yourself? Gut shots are available and pcb is numbered.
perwin wrote:Also, do you have this scheme and/or pcb design available for download in format for Eagle or KiCad?
Thank you.
http://www.hobby-hour.com/electronics/s ... tainer.php
viewtopic.php?f=1&t=4405
https://www.diystompboxes.com/smfforum/ ... ic=28369.0
