Dr J - D55 Aerolite Compressor
Posted: 26 Dec 2013, 09:18
by mysticwhiskey
I haven't yet fully traced the circuit, but I'm about 75% done and at this stage it is looking like it's a Boss CS-2 with a blend mod to mix the dry and compressed signal.
IC is LM13700N, FETs are J201 and transistors are 2N3904.
Re: Joyo Dr J D55 Aerolite Compressor [schematic]
Posted: 28 Dec 2013, 04:30
by mysticwhiskey
Confirmed: This is a Boss CS-2 clone (using a LM13700N instead of BA662A), with adjustable blend of compressed/dry signal.
Posted: 28 Dec 2013, 20:45
by artaommahe
So it's half of LM13700 here witout buffer and diode-bias, so can we use CA3080 here? Using less space..
Re: Dr J - D55 Aerolite Compressor
Posted: 11 May 2016, 19:04
by perwin
I miss values of rezistors in the scheme. Could you please post them?
Also, do you have this scheme and/or pcb design available for download in format for Eagle or KiCad?
Thank you.
Posted: 11 May 2016, 19:24
by modman
perwin wrote:I miss values of rezistors in the scheme. Could you please post them?
Why don't you do some of the work yourself? Gut shots are available and pcb is numbered.
perwin wrote:Also, do you have this scheme and/or pcb design available for download in format for Eagle or KiCad?
Thank you.
http://www.hobby-hour.com/electronics/s ... tainer.php
viewtopic.php?f=1&t=4405
https://www.diystompboxes.com/smfforum/ ... ic=28369.0
