D*style distortion/OD  [traced]
box
Been thanked: 35 times
Post by box »
link to the tube-ish distortion:
https://www.diystompboxes.com/pedals/sc ... panova.pdf
Just change : D1-12V Zener,C2-4u7, C4-47nF,C7-47nF,add resistor 47k between Drive 1 and Gnd,R15-15k,C13-33nF,R16-3k9
Q1-D=5.17V,G=0V, S=0.825V
Q2-D=6.58V, G=6.58V,S=0.482V
Q3-D=7.27V , S=0.271V
Q4-B=7.28V,E=6.64V, C=9.05V
Enjoy .
Rgds,
box
box
Post by box »
demo for this pedal from the net:
http://www.soundclick.com/bands/page_so ... layer=true
Rgds,
box
fakcior
Been thanked: 20 times
Post by fakcior »
Description says it's Pearl Drive by OceanFX
box
Post by box »
fakcior wrote:Description says it's Pearl Drive by OceanFX
Everything is correct.
Schematic with modification it's matching this demo :D
Rgds,
box
J0K3RX
Has thanked: 315 times
Been thanked: 555 times
Post by J0K3RX »
That is some KILLER tone!!
Manfred
Has thanked: 1597 times
Been thanked: 1300 times
Post by Manfred »
Hi Box,
did you select the J201 Fets for this circuit?
box
Post by box »
Manfred wrote:Hi Box,
no I didn't select. Just adjust value of the voltage.
Rgds,
box
Has thanked: 218 times
Been thanked: 857 times
Thanks. :thumbsup
How much influence does including that C10-R10 really have?
Ripdivot
Been thanked: 78 times
Post by Ripdivot »
Dirk_Hendrik wrote:Thanks. :thumbsup
I have the same question. R10 seems like it's not correct, 10meg is way too high. Seems like 10k would make more sense.
box
Post by box »
Guys,
if do you compare original schematic and some changes you can notice that C10-R10 left without any change.
Always you can experiment to choose the best sound for you.
Rgds,
box
Manfred
Post by Manfred »
Rgds,
box
Hi Box,
thanks!
How did you make the setting, by listen to achive the best overdrive sound
or e.g. by oscilloscop to get a symmetrical clipping?
Rgds,
Manfred
box
Post by box »
Rgds,
box
Hi Box,
thanks!
Rgds,
Manfred
Hi Manfred,
You are wlcme.Please try first to follow voltage adjustment but if you are not happy with this next step to achive the best overdrive sound.
Rgds,
box
Manfred
Post by Manfred »
Hi Box,
thanks again!
The frist step will be to build the device,
then I will follow the setting procedure as you recommended.
Rgds
Manfred
Guys,
Rgds,
box
Uuh,
Scuse me for being ignorant and apparently at a wrong wavelength and somehow missing something. What I see is a .pdf with a schem and build instructions. Therefore;
- which original schematic?
- which "some changes"
And asking questions on questionnable parts of a circuit does not mean "can I experiment?" It means "What was you motivation for doing this?".
box
Post by box »
Guys,
Rgds,
box
Uuh,
original schematic is the one in the first post pdf and build instruction. My modification some of the components it's mention below the link.
If schematic was already published on the net I can't see any restriction to modify and motivation is always the same "to achieve sound according
my requirement"- similar to D*mble.
Most important that there is no claim that it's my design .Demo it's very close sound what I get it .
I hope so that no more explaination is required :D
Rgds,
box
OK I' get it now.
Bottom line is that apparently Nagy published this design and so far nobody (googled) ever wondered about this oddity in the circuit.
Or is this one of these add-on's in hope to be one of these "and I added bullshit to the design and they just copied it in their clone" bullshitters?
box
Post by box »
Dirk_Hendrik wrote:OK I' get it now.
blah blah :mrgreen:
Manfred
Post by Manfred »
thanks again!
Rgds
Manfred
have a look at the article there:
http://runoffgroove.com/fetzervalve.html
The article contains a Vp and Idd measuring circuit.
at the end of the page apears an online JFET stage calculator
to determine the stage parts values depends on Vp and Idd.
Rgds
Manfred
