From IC PC Board to Vero?
I don't need the ground wire? At all? Thought the toggle would need to be grounded just like the footswitch... Or do neither the toggle or footswitch need the ground?
So DPDT toggle like this then Also, I can use two mono jacks right? No need for a stereo jack anywhere, not planning on including a 9v Battery in this, just the DC adapter socket.
- induction
That's right. The ground is just for the led. When the circuit is engaged, the cathode of the led is grounded and the led lights up. When you switch to bypass, that grounded lug is no longer connected to anything else in the circuit. The body of the switch is isolated from the lugs, and is grounded via the enclosure it you use a metal box and non-isolated jacks. Otherwise it's ungrounded unless you explicitly ground it somehow. With a 9V circuit, it's not crucial to ground the switch for safety, but it's good practice anyway.
And yes, when you don't use a battery, mono jacks are fine.
So the Veros are done, need testing but I dont know which lug of the 2.1mm DC Jack is + and -...
It has two lugs, one shorter than the other. I assume the longer one is positive but wanted to check - So which is which?
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
Check continuity with a DMM?User6121 wrote: I assume the longer one is positive but wanted to check - So which is which?
- induction
I'm not familiar with that socket, but I'd guess the short lug is ground because of how close it is to the center. You should check to be sure before you connect it to the circuit. If you don't have a DMM, you can wire up an led and a limiting resistor and see which polarity makes it light up.
