Still hoping for the ?Flanger....
Lovetone - Wobulator schematic [traced]
Although posted before....just for getting a nice collection here
Wobulator_v3.pdf- (227.48 KiB) Downloaded 203 times
- Dirk_Hendrik
Hey Markus!
Ended up here too huh? Good to see you!
- briggs
Hey Timm,tuemmueh wrote:Hi markus!
What about the layout? IIRC somebody was working on one ... Do you know the status of the project?
Cheers ~ Timm
I'm sorry, I just realised that there were some efforts but I did'nt follow the thread for quite some time.
Markus
Hi Timm
I was the guy who was working on a layout and produced the first prototype. The schem given by Markus has been confirmed and works in "real life" my layout (over at diystompboxes) works but there is tick which this circuit suffers from. The layout is not optimised to reduce tick (it was my first ever layout!) so all the information is there to build yourself one. When I get time i was going to write up a project file for it so it has information for the types and values of components that I used.
Have fun, if you run into any problems give me a shout on either forum.
Shed
Shed
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
- LaceSensor
that might be my photo...hmm?
anyway, this has been reversed by a couple folks already... traces, single side etch and double side Oshpark projects are out in the public domain
the big problem is getting the right LED / LDR combo
- gigelmargel
Hello,LaceSensor wrote:that might be my photo...hmm?
Where I can find a PCB for Wobulator? I searched, but with no luck
Thank you very much!
- marmaliser
- gigelmargel
Thank you very much mamaliser!!!marmaliser wrote:Check the projects here http://www.madbeanpedals.com/forum/inde ... ic=17402.0
- LaceSensor
note my point above about the correct LED and LDR
I made the wobulator on the PCB project here: https://oshpark.com/shared_projects/lg94calD
and it doesnt sound nearly as good as my real unit...
