so how do you wire the input so the battery disengages......
Locked
vanguard
Post by vanguard »
...when you pull the cord out? i just built a pedal, and you can switch it on/off even when the input cord is pulled out. how do do this?
thanks
Have a look at this overview page at GGG, you will need a different diagram depending on the fact you use LED and DC jack or not.
have fun
The easiest way is to use a stereo input socket - three connections: Tip, Ring, and Sleeve.
Tip is for signal input
Sleeve is for ground connection
Attach the black wire from your battery clip to the Ring connection
All done :wink: :applause:
schumann
Post by schumann »
Hi all!
Hey i went to try out some of my friend's boutique pedals and I noticed that when my input/output is disconnected, the power/battery is cutted off and the LED would not light up. If i plug in a DC(off) my battery is cutted off and the LED would not light if i press the switch. Anybody has any ideal what i'm talking about? and knows how to do that? I want to do that to save battery power in my DIY pedals.
Some help from the pros around here?? :wink:
Thanks man!
I merged your message into a thread that already answers your question (I think....
:mrgreen:
schumann
Post by schumann »
thanks alot man! :D
bencoles
Post by bencoles »
hi there just finished building an A/B box to this layout, but just realised that if i used battery the leds are always on, i know there is a way to use a stereo jack to break the battery circuit when no jack is inserted but am a little unsure how to do this. If someone here could help that would be guuuureat! :)
himister
Has thanked: 21 times
Been thanked: 28 times
Post by himister »
bencoles wrote:i know there is a way to use a stereo jack to break the battery circuit when no jack is inserted but am a little unsure how to do this. If someone here could help that would be guuuureat! :)
Hi.
Change the input jack to stereo (TRS - tip, ring, sleeve) and connect battery ground (- negative) to middle one it's the ring, so when you plug cable jack it will connect negative battery supply to ground (ring and sleeve connected) and that's it! :wink:
Just like any other pedal, when you unplug the input cable it will brake the circuit and consume the battery life!
Cheers :thumbsup
Merged into an existing FAQ thread...
Locked
