Making a VTL5C3 optocoupler
Mrutg
my favorite amplifier: MG Fendmess
Completed builds: Fuzz Factory,
Has thanked: 10 times
Post by Mrutg »
As far as i am concerned - it's a diode with photoresistor. I have seen people making them from diode and photoresistor elements.
But what should i take into consideration when chosing them for a optocoupler - ?
Will standard (on off red light diode) be ok? How to chose the photoresistor basing on On resitance and OFF resistance of an optocoupler datasheet?
This is for the McMeat clone.
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
Meatball/McMeat is not too picky about optocoupler used since the intensity control has an influence on the responce as well. It's more important that the two photoresistors/LDRs used for the two optocouplers have similar specs: I'll look at home tonight for the ones I used.
Mrutg
Post by Mrutg »
Looking foreward for your reply!
Nocentelli
Ok. I found the packaging they came in but it doesn't have the specs on. They are 5mm from Tayda, and I measured them before I put them in, and I recall they were around 1M in darkness and just under 1k fully illuminated. I'll just re-iterate that a) the specs aren't that critical since both the sensitivity pot and the intensity pot have a major influence on the sweep in conjunction with the response of the LDR, b) it's more important that whatever the spec, the two LDRs you use have SIMILAR specs for maximum filtering effect, and also c) when you actually measure them, they are not always that close to the specs quoted.
I used green standard 5mm LEDs.
