Change position of inverting pin for opamp in EagleCAD
fishfude
Has thanked: 37 times
Post by fishfude »
Hiya folks,
I'm completely frustrated trying to change an LM741 opamp schematic symbol in EagleCAD, so that the inverting pin is at the top and the non-inverting at the bottom. The default is the other way round. I've tried 'gateswap' and 'pinswap' and editing in 'Open Symbol' (which I can edt in but not seem able to save).
Any help is greatly appreciated.
ff
jubal81
Has thanked: 50 times
Been thanked: 30 times
Post by jubal81 »
Did you try 'mirror' and then rotate it?
astrobass
Has thanked: 42 times
Been thanked: 74 times
Post by astrobass »
Yeah just mirror it. No need to do anything weird to the library files.
Intripped
Has thanked: 941 times
Been thanked: 303 times
Post by Intripped »
Tip: to mirror any object just click the scroll wheel button
astrobass
Post by astrobass »
Intripped wrote:Tip: to mirror any object just click the scroll wheel button
Or right click it and select mirror, or click on the toolbar icon had looks like a capital E with a vertical line between it and a mirrored capital E and click each thing you want to mirror.
Intripped
Post by Intripped »
or you can write "mirror" in the command line and press ENTER and then click on the objects you want to mirror
...just for completeness :)
