Change position of inverting pin for opamp in EagleCAD
Posted: 23 Jan 2014, 14:27
by fishfude
Hiya folks,
I'm completely frustrated trying to change an LM741 opamp schematic symbol in EagleCAD, so that the inverting pin is at the top and the non-inverting at the bottom. The default is the other way round. I've tried 'gateswap' and 'pinswap' and editing in 'Open Symbol' (which I can edt in but not seem able to save).
Any help is greatly appreciated.
ff
Re: Change position of inverting pin for opamp in EagleCAD
Posted: 23 Jan 2014, 16:53
by jubal81
Did you try 'mirror' and then rotate it?
Posted: 30 Jan 2014, 04:06
by astrobass
Yeah just mirror it. No need to do anything weird to the library files.
Posted: 30 Jan 2014, 04:24
by Intripped
Tip: to mirror any object just click the scroll wheel button
Posted: 06 Feb 2014, 15:18
by astrobass
Intripped wrote:Tip: to mirror any object just click the scroll wheel button
Or right click it and select mirror, or click on the toolbar icon had looks like a capital E with a vertical line between it and a mirrored capital E and click each thing you want to mirror.
Posted: 06 Feb 2014, 19:26
by Intripped
or you can write "mirror" in the command line and press ENTER and then click on the objects you want to mirror
...just for completeness :)
