Plexitone Original
AAntonio
Has thanked: 19 times
Been thanked: 16 times
Post by AAntonio »
here are some photos, pcb working
the original Plexitone
if someone from the pictures can do a better pcb, it would be great
but still working
pcb plexitone originale.jpg (45.75 KiB) Viewed 1857 times
AAntonio
Post by AAntonio »
pcb plexitone originale ( verso led).jpg (26.53 KiB) Viewed 1854 times
AAntonio
Post by AAntonio »
nobody cares? :)
Chugs
Has thanked: 63 times
Been thanked: 47 times
Post by Chugs »
Thanks for your contribution.
Lack of interest my be due to this thread...
https://www.freestompboxes.org/viewtopic ... =plexitone
bucksears
Has thanked: 16 times
Been thanked: 41 times
Post by bucksears »
I think the big reason is that it is easier to source/build out the charge pump portion of the circuit (and run it off of a standard 9V-12V barrel supply) than it is to build the transformer version and wire in a fixed power plug.
You've done a commendable job tracing out the larger/original version (I took multiple high-res shots of both sides of the board of my previous one before selling it), but the other complaint folks have is the size. I never used the Boost on my stock one, so when I built out the DIY version, I just have on/off and crunch/high gain footswitches. Works fine in that config, in a Hammond BB-size turned sideways.
I did the same thing with the AC-Tone too.
