wtb - SAD 512D
Posted: 29 Jan 2014, 09:13
by candletears7
My trusty early 80's MXR Micro Flanger is now passing clear signal on and off. I suspect the chip although I haven't taken voltages as yet...
Anyone selling SAD 512D's at all just in case?
Cheers.
Re: wtb - SAD 512D
Posted: 29 Jan 2014, 16:54
by Govmnt_Lacky
candletears7 wrote:My trusty early 80's MXR Micro Flanger is now passing clear signal on and off. I suspect the chip although I haven't taken voltages as yet...
Cheers.
Never just assume it is the SAD. Those are Unicorn tears and it would behoove you to make every attempt to verify that it is NOT the BBD.
In any case, I happen to have the Reticon R5106 chip if you are interested. It is known to be a good drop in replacement for the SAD512D.
Good Luck :thumbsup
Re: wtb - SAD 512D
Posted: 29 Jan 2014, 17:59
by Dirk_Hendrik
Govmnt_Lacky wrote: Never just assume it is the SAD. Those are Unicorn tears and it would behoove you to make every attempt to verify that it is NOT the BBD.
I fully second the above.
Re: wtb - SAD 512D
Posted: 30 Jan 2014, 01:32
by candletears7
Appreciate the input guys, thankyou.
I won't be able to check the pedal till tonight but I'll probe and take voltages from the schematic.
Depending how I go I may take you up on the offer, Lacky, thankyou.
Re: wtb - SAD 512D
Posted: 31 Jan 2014, 14:09
by Govmnt_Lacky
The fact that it is still passing a modulated signal occasionally tells me that you may only need to readjust the BBD bias a bit.
Did you ever get a chance to look at this?
Re: wtb - SAD 512D
Posted: 03 Feb 2014, 01:00
by candletears7
Hey mate, no I've been absolutely thrashed with a new job, family life and bands! :(
I haven't even printed off the damned schematic yet!
I briefly had a look at the trim pot but it's glued or sealed in position. I may just have to break the seal and see if it works.
I do appreciate the input from you though - I put this little guy after my dirts set to minimum on both dials. Huge thick modulated signal that just sounds massive on stage.
Re: wtb - SAD 512D
Posted: 15 Feb 2014, 06:18
by candletears7
Well, for anyone reading along with this, all voltages on all chips and caps are as per schematic...except the 4069 Hex Inverter. That and it's hot as hell. Its out, a socket is in and tomorrow I'll grab another. Here's hoping that's the issue and not the SAD.
Re: wtb - SAD 512D
Posted: 15 Feb 2014, 16:56
by Dirk_Hendrik
Fingers crossed!! :thumbsup
Re: wtb - SAD 512D
Posted: 16 Feb 2014, 04:41
by candletears7
Thanks Dirk, but alas, still no joy even with a new socketed 4069.
I've got a feeling it's something to do with that oscillator...next step is to check for any dodgy connections and to measure the electrolytics.
Mods may as well move this to a vintage MXR Microflanger thread if it exists as now this is debug.
