frequencies in guitar
Posted: 11 Feb 2014, 17:52
hi, i was thinking about freq in guitar but im not sure about i, i mean for example highs, mid or bass, if i ant to set a filter for each freq, what would be the setting freq of each???
phatt wrote:Just work out what frequencies the guitar covers (See the coloured graph on the link Duckman posted)![]()
Every octave is a doubling of Freq,,So
Tenor guitar;
Bottom E string is 82Hz
4th String second Fret =164
Open top E string =328
12th fret =656
24th fret =1312
From there up is harmonics;
2624Hz and 5248Hz.
Past that is likely to hinder the chase for mojo tone.![]()
caveat;
If all you do is strum a few chords on a clean guitar then bandwidth won't matter much
BUT once you introduce light too hard driven distortion then limiting bandwidth is VITAL to success. Distortion is easy to make happen the magic is in the tone shaping and that is the hard part to nail down.
IME, the magic points are notch cut around 400Hz and then again somewhere between 700 < 1kHz.
That in either separate or combination will cover most of the classic rock sounds.
Metal you can boost the bottom end as well as a mild scoop.
If you want the midrange honk then invert the 400Hz and the 700Hz. Don't boost above ~1500Hz as it will get brittle fast and destroy the sweetness.
There is no Exacts as all this is highly dependent on a multitude of variables from pickups to speakers used and dozens of places in the Amplification circuits used.
I've spent hours fine tuning the magic smoke of circuits I've built and just when I've found the magic.
Well I take to the gig and it sounds like crap.
the environment (Room acoustics) also plays a big role in the end result.![]()
Phil.
