BigShot - ABY Passive
I'd like to make a simple passive "Y" splitter to feed two amps even if the amplifiers have large "ground" voltage differences. The "BigShot ABY" appears to do that but I can't find the model of the transformer used in the circuit and I don't need the A-B selection ability.
Attached is the block diagram for the BigShot. Can anyone suggest an appropriate make/model transformer?
PS - also attached is the spec sheet for the OEM transformer.
Thanks. Do you think this Edcor model would do the trick? http://www.edcorusa.com/p/143/wsm600-600http://www.edcorusa.com/p/143/wsm600-600
WSM600/600
1/2W 600 Ohms to 600 Ohms (1:1) line level matching transformer.
WSM600/600
