is this a good deal?
meek
Post by meek »
http://www.aliexpress.com/item/Total-12 ... 49574.html
it looks like this site has everything you'll ever need for stompboxi'n :)
search result; http://www.aliexpress.com/wholesale?Sea ... 1007012505
Has thanked: 218 times
Been thanked: 857 times
No, since it contains values you hardly ever use in the same quantity as other values which you may run out of in one repair job.
But, after that, and the not that great price tag, it can be a damn handy set to have around.
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
+1 on that! I find myself using 1µF, 4.7µf, 10µF 22µF, 47µf and 100µF electro's over and over again. None of those at a 50V rating vill set you back more than $0.04 a piece from tayda ;) Price for 120 pieces is about the same as the link you posted, but what's good about it is that you get to choose the values you need, instead of bulk buying stuff you don't need ;)
meek
Post by meek »
yeah, that Tayda was a awesome site.
better to buy those you use often as you stated ;)
