clone xotic bb preamp problem
ballfire
Has thanked: 38 times
Post by ballfire »
hello evrybody, i built the bb preamp the output is fine but the problem theres crackling noise at the output. what is the problem of this any advice? thank you.
ballfire
Post by ballfire »
why is it theres no replying??
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
Because you haven't really given any information. If you want help debugging a build then we need to know what layout you used, see pictures of the board, voltages of the transistors and ICs. So sometimes people are waiting for the person with the problem to post a little more information.
Crackling can be caused by a few things, and sometimes it's expected, but not with this circuit. When I hear someone has a problem with an effect crackling the first thing I think of is that there is a bad connection somewhere. A bad solder joint can cause all sorts of noise, but again we'd be in a better position to help if we could see a pic and so had a good idea of the soldering job you'd done and maybe point out a few areas to check.
Post pics and voltages and I'm sure you'll get more people willing to help.
ballfire
Post by ballfire »
thank you for the reply.. IvIark
ahh..i thought nobody cares no more in my questions..
anyway thanks i appreciate it man for replying me..
i wil check again the connection and parts and test it again .
thank you..i like this place of comfort full of diy effects yahooo..
biliousfrog
Completed builds: Zen Drive, Fuzz Factory, Really Cheap Compressor, D*A*M 66, Klon Buffer, CryBaby mods, Boss TR2 mods, Various loops and switchers, DOD250, Fulltone Bass Drive, MXR Bluebox mods
Been thanked: 9 times
Post by biliousfrog »
You could also try posting in one of the more relevant sections.
ballfire
Post by ballfire »
good day
i resolve the problem..this bb preamp has a good effect when i playing it..but theres a very slight distortion effect when the effect is off..
any advise..thank you
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
ballfire wrote:theres a very slight distortion effect when the effect is off..
I guess it's true bypass - check for bad solder joints at the switch and eventually the jacks. Check the guitar cable too.
ballfire
Post by ballfire »
thanks for the advice..i will check it
ballfire
Post by ballfire »
hello everybody
after days of testing .i finally fixed my bb preamp, it sound good.
snofla1900
Has thanked: 83 times
Been thanked: 7 times
Post by snofla1900 »
But how did you fix it , was the problem you solved ?
Alf
