it consists of:
a base (offcut of some decking timber I had)
a flushmount from a light switch
some plastic waterpipe
some dowel
a plastic waterpipe mounting bracket
a piece of thin timber to which the bracket above is screwed
a DC drill with 0.8mm chuck (ex ebay for <US$10)
some kind of spring (yet to get this)
some screws to hold it all together
I sourced some pipe from the hardware store (they only sell like a metre at a time so I have way too much now) and found some dowel there too which fit a lil too tight inside... sanding required to ensure the dowel slides up and down inside the pipe.
I attached the flush box to the base board, then drilled a hole in the wood and inserted the pipe.
I cut a straight (at least that was the intention, and in mine is not ,but I have plenty of pipe left so the next one will be better
I aligned the slot so it's at the front and then flipped it over to drill a hole for a small screw through the inside of the base end of the pipe to ensure it can't spin. next, I mounted the DC motor (drill) to a small piece of timber I had (offcut from some trellis) with the waterpipe bracket then lined it up so the drill was straight with the the cut slot (waterpipe) and mounted the trellis timber to the dowel with some screws leaving slightly more than the width of the pipe wall gap between the down and trellis timber.
slide the dowel into the pipe and it's all ready to drill straight up and down.
I need to source a spring to put in the bottom of the pipe and then I'll screw a metal plate over the hole underneath and presto.. should have a mini drill pres.
I'll wire up a switch for the unit on the side and will prolly make up a plate that the drill can pass through and PCBs can sit on.
it looks budget as hell but that stands to reason since it's made to a budget...
