Constant swich into momentary.
Posted: 16 Mar 2014, 18:09
Can someone please suggest a circuit that would convert constant switching into momentary switching.
I need this with my diy amp/pod footswitch. I'm using a 3PDT footswitch where first contacts switch amp channel, second contacts turn footswitch LED on/off and I need the third contacts to switch my pocket POD's presets up and down, but for that I need a momentary connection.
Pocket POD footswitch mod can be found here: http://joekataldo.com/blog/pocketpodfootswitchmod/61
I'm going to power the footswitch from a 9VDC supply. So I'm hoping to power the constant to momentary circuit by that aswell.
I have had no luck finding a relay that would do that.
All ideas appreciated.
