change micro switch for dpdt
copachino
Post by copachino »
hi, a friend have a real bad pedalboard, a zoom, but it have many cheap components, most of the are the switches, the switches for the banks are mini switches, like this
http://www.alpha-crucis.com/1861-2351-t ... button.jpg
so i was thinking thta maybe its possible to change them with a momentary dpdt, would it be possible??
pedro.deus
Post by pedro.deus »
This switch is a tactile switch most common know-ed a latch/ momentary switch. You have 2 possibilities remove the digital/ buffer switch and add a analogue DPDT or 3PDT. Or de-soldering the switch and use a momentary SPST footswitch.
