ESP Cinnamon 3 Band EQ for Bass
darmstat
Been thanked: 54 times
Post by darmstat »
Hello....Does anyone have a schematic of the ESP Cinnamon 3 band band on board bass eq?
Ichabod_Crane
Has thanked: 58 times
Been thanked: 31 times
Post by Ichabod_Crane »
Bump!
I'm looking for something about this ESP bass preamp, too.
I just found this manual: https://espguitars.co.jp/guitarparts/wp ... Manual.pdf
darmstat
Post by darmstat »
I have a esp cinnamon 3 band eq and I am trying to trace it. Here is the information I have. Can someone look over my schematic and see if it is correct or will work. Thank you
darmstat
Post by darmstat »
Schematic
darmstat
Post by darmstat »
Sch
darmstat
Post by darmstat »
Pic 1
darmstat
Post by darmstat »
Pic2
darmstat
Post by darmstat »
Pic3
darmstat
Post by darmstat »
Pic4
darmstat
Post by darmstat »
Pic5 the traces are all on one side. No top traces.
Ichabod_Crane
Good job. I'm going to see it better later.
The G
Grease Monkey
Has thanked: 407 times
Been thanked: 282 times
Post by The G »
This is what I could make sense of:
The 3rd op amp is most likely a single low-power op amp and its pinout should be the same as TL071. I named the double potentiometers' sections as "top" and "bottom", "top" being the closest section to the shaft.
Unfortunately, both the schematic and the wiring diagram are truncated. Also, I'm not sure about "passive treble", "B1", "B2" and "trimmer". Could you post an image of the gain trimmer?
Please let me know how close am I to the real thing, so I'll be able to draw a schematic.
darmstat
Post by darmstat »
The gain is the root white wires next to each other. One wire connected to pin one of gain trimmer and the other wire connected to pin 2 and 3 of the same gain trimmer
darmstat
Post by darmstat »
Manual
Cinnamonn-Manual (4).pdf
(440.86 KiB) Downloaded 133 times
darmstat
Post by darmstat »
Wiring
The G
Grease Monkey
Post by The G »
The schematic appears to include some questionable circuit choices. The one I like the least is biasing IC1B through no less than two resistors and two potentiometers :shock:
LATER EDIT: I forgot to put a +9V wire on the layout. You most likely figured it out, the red is +9V, green is Vref and black is GND.
darmstat
Post by darmstat »
Very strange indeed. Thanks for your help.
george giblet
Has thanked: 180 times
Been thanked: 272 times
Post by george giblet »
There's a little weirdness here and there.
I'm fairly certain the mid control has an error:
C9 should connect between IC2A pin 2 and the Mid pot pin 2 (wiper)
R13 should connect from IC1B pin 7 (where it already is connecting) to IC2A pin 2
If you search midrange control you should find many examples of the pattern. It is a very common midrange circuit.
Even the ratio of the capacitors C10/C9 is fairly typical.
(The input side of the Treble control only works with a passive pickup.)
