Full tube 3 channels guitar preamp
- DarkRain
Hey guys, this is my latest build. A 3 channel guitar preamp. Main features:
- 3 switchable channels (it can be done MIDI compatible);
- switchable cab-simulator
- Separate EQ and Gain/Volume controls for Clean / Crunch-Lead
- uC switching system
Soon sound samples.
Best regards,
Gabriel Tudoran
Analog Sound
Soon sound samples.
Best regards,
Gabriel Tudoran
Analog Sound
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
Looks really cool, I'm interested in building something like that so I can use it with my Behringer K3000FX Keyboard/PA Amp, would also be handy in a recording studio situation......
- rcustoms
JAJAJAJ0K3RX wrote:That's it?You're gonna leave us all standin around with our pants around our ankles, a boner and not give us a happy ending??
i agree with you
- DarkRain
Best regards,
Gabriel Tudoran
Analog Sound
- DarkRain
Ok, as i promised, here are:
- preamp schematic
- hv psu schematic
- pcb transfer for both of them
- topsilk for both of them
Any question will be answered
Best regards,
Gabriel Tudoran
Analog Sound
PS: the PSU requires a Xformer with this data: primary 120 or 220v, secondary: 6.3v @ 1.2A and 190-0-190 @ 20mA
PPS: the switching mode is one of your choice (you can use relays or you can use switches), the lead channel use all triodes form the top
- preamp schematic
- hv psu schematic
Best regards,
Gabriel Tudoran
Analog Sound
HV_PSU_PCB.pdf- (11.62 KiB) Downloaded 234 times
HV_PSU_TOPSILK.pdf- (20.94 KiB) Downloaded 197 times
HV_PSU_SCH.pdf- (8.07 KiB) Downloaded 285 times
PREAMP_PCB.pdf- (46.67 KiB) Downloaded 260 times
PREAMP_TOPSILK.pdf- (102.84 KiB) Downloaded 232 times
PREAMP_SCH.pdf- (21.09 KiB) Downloaded 395 times
- DrNomis
Cheers for that DarkRain......
- J0K3RX
- Degoop Doctor
Looks interesting.. I really like the backlit blue LED face plate and knobs! Would like to see the MIDI and cab simulation. Hope to hear some samples and see some guts...
- DarkRain
Sloppy sample:
Some guts pictures i will post them today.
Best regards,
Gabriel Tudoran
Analog Sound
Best regards,
Gabriel Tudoran
Analog Sound
J0K3RX wrote:Looks interesting.. I really like the backlit blue LED face plate and knobs! Would like to see the MIDI and cab simulation. Hope to hear some samples and see some guts...
- DarkRain
Nice work there...
I'm looking for a toroidal power transformer to build a guitar preamp and was wondering if you could tell us the make and model of the power transformer you used in your build...
Thanks,
TT
Thanks,
TT
- DarkRain
Hey TT,
It's a custom made toroidal. I's made in Romania and the price was about... 35-40$ The specs are 220v primary, 3.15-0-3.15v @1.2A and 190-0-190 @ 20mA
I can help you build one here but ... i guess is too much hassle to send it to you.
Best regards,
Gabriel Tudoran
Analog Sound
PS: i don't think that you will find a toroidal transformer that will suits your needs ready available .
Best regards,
Gabriel Tudoran
Analog Sound
tictac wrote:Nice work there...![]()
Thanks,
TT
- DrNomis
I wonder if it's possible to build this into a 1U or 2U 19 inch rackmount case......
- J0K3RX
- Degoop Doctor
I don't see why not... make a new layout with a tube daughter board and mount at right angle so the tubes are horizontal inside the case. Not uncommon..DrNomis wrote:I wonder if it's possible to build this into a 1U or 2U 19 inch rackmount case......
I am trying to figure out what other tube preamp this is a spin off of? Looks like a combination of a few?
- DarkRain
@DrNomis: Yes it it possible. In fact i had that thought ... but i choose this type of enclosure (is more like a desktop preamp).
@J0K3RX: In fact is a combination of only... 1 preamp, and we are talking about Diezel, but skiped some parts, lef aside a channel... modified some values, changed switching points ... and this is it.
Best regards,
Gabriel Tudoran
Analog Sound
Best regards,
Gabriel Tudoran
Analog Sound
- J0K3RX
- Degoop Doctor
If you have an enclosure that has the head room then why not keep'em standin up...DarkRain wrote:@DrNomis: Yes it it possible. In fact i had that thought ... but i choose this type of enclosure (is more like a desktop preamp).
Best regards,
Gabriel Tudoran
Analog Sound
Diezel you say... What model? hmmm?
Diezel VH4.pdf- (1.01 MiB) Downloaded 89 times
- DrNomis
I'm seeing a bit of a Marshall/Fender influence in the component values in the preamp and tonestack circuits, I need to sort out my PC's sound so I can check out that soundcloud link so I can get a bit of an idea of what the preamp sounds like, but deffinitely a cool looking project, I like the Blue Led back-lighting, certainly gives it that High-Endy look.....
I'm rapidly becoming a fan of your work, DarkRain......
- DarkRain
The tonstacks were tweaked according to taste. And yes... some known preamp models were used but none of them was copied
Thank you DrNormis for your kind words. Now i'm working on a full tube pedal (similar with GTFO but with some tweaks and options). SMPS based, 2xECC83 (12AX7).
A small preview of the SW project.
Best regards,
Gabriel Tudoran
Analog Sound
Best regards,
Gabriel Tudoran
Analog Sound
- DrNomis
DarkRain wrote:The tonstacks were tweaked according to taste. And yes... some known preamp models were used but none of them was copied.
Best regards,
Gabriel Tudoran
Analog Sound
looking cool so far, can't wait to check out the project......
I found a toroidal PT that will work for a tube preamp; Antek: AS-1T175 it will put out around 250VDC rectified and is rated at 100VA
There is also a 300V version; they changed part numbers from "AN" to "AS" which may be why it's been hard to find...
TT
TT
