Earthquaker Devices - Talons [traced]
- Gila_Crisis
Hi folks,
do anyone here have some information about this pedal?
I tried to google it and I found this gut picture.
it seams not to be an uber-complicated circuit!
thanks for the help
thanks for the help
- eqdtalons5.jpg (44.8 KiB) Viewed 4665 times
- zedsnotdead
Ok so i got hold of one of these beasts and took several guts photos.
I didn't want to take the pots apart, pedals not mine and the owner didn't want any piece of detailed info of it to be public (hence the blemished date and so...)
Sorry for the crapy photos, but that's all I could shoot at the time.
Hope it helps!
Cheers!
Hope it helps!
Cheers!
possibly a Guv'Nor. (just my guess)
- zedsnotdead
Forgot to mention: Leds are clear red.
- zedsnotdead
Ah, one other thig. I still have the pedal with me for a week or so. If you need me to check anything just ask and Ill do my best.
Cheers!
Cheers!
- zedsnotdead
I'll try to get some values and post them here.
- zedsnotdead
- zedsnotdead
Pictures from my first post are front and back.
I know it's hard to see the tracks, mainly no the backside, but those were the best I could take.... sorry.
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
Thanks for this! I think the presence control should probably be connected to the inverting input of IC1 instead of the output, and the three tone controls should have their wipers connected to the inverting input of IC2.
- zedsnotdead
Just talked to the owner of the pedal, he said I could keep it for a couple of days more
So, I don't want to take it apart, but I'll try to verify the connections with a multimeter. If it beeps it's ok
If not... i'll figure it out and correct the schematics (thank you so much darmstat!!!!
- Nocentelli
Yep. And you would normally expect the resistor hanging off the IC1 non-inverting input to be connected to vref rather than ground, and to be smaller in value. I wonder if the 3M3 and cap to ground pair are actually connected to the "guitar side" of the input cap, and there is a different bias resistor somewhere (usually 1M or 470k in this type of circuit) connecting the opamp input to vref? I say all this from the perspective of not having spent hours studying the trace itself, so it is just speculation.
- darmstat
This my best guess with the pictures and i think i am missing just 2 resistor( 2 x 10k ) which could be somekind of voltages dividers. I am not sure. Please feel free to correct or toss in an oven....lol
