Earthquaker Devices - Talons  [traced]
zedsnotdead
Has thanked: 31 times
Been thanked: 54 times
Post by zedsnotdead »
:thumbsup
On bass guitar also?
johnk
Has thanked: 36 times
Been thanked: 293 times
Post by johnk »
yup.
andregarcia57
Has thanked: 50 times
Been thanked: 96 times
Post by andregarcia57 »
OSHPARK file-based layout storyboardist
I made some minor changes in layout. I prefer lying electrolyte.
unchecked.
johnk
Post by johnk »
got mine all boxed up today. it would've been a lot easier to wire up with board mounted pots but it sounds great just the same. I also added a relayed true bypass.
zedsnotdead
Holy 5hit John!! That's awesome!!!
Did you paint the enclosure yourself?
How did you get that image on the enclosure? It's the same as the original talons!
Good job my friend!
andregarcia57
johnk wrote:got mine all boxed up today. it would've been a lot easier to wire up with board mounted pots but it sounds great just the same. I also added a relayed true bypass.
[ Image ]
[ Image ]
hello beautiful Mount.
the relay are you using this?
johnk
Post by johnk »
zedsnotdead wrote:Holy 5hit John!! That's awesome!!!
Good job my friend!
thanks.
it's just a powder coated translucent gold enclosure with a decal and 4 coats of clear over it.
johnk
Post by johnk »
yes, but it's modified to use a different, smaller relay.
Visualdistortion
my favorite amplifier: Laney
Completed builds: Many...
Been thanked: 23 times
Post by Visualdistortion »
[ Image ]
[ Image ]
Really great, what brand of decal and clear coat did you use? I will love finish my pedal like this.
I wanna make it
I wanna make it wit chu
(again and again and again)
French... sorry ;)
andregarcia57
Relay
zedsnotdead
You know what would be really cool?
Designing a relay PCB that could be used with Moment-spdt pcb-mounted switches like these:
or these dpdt:
That would be uber cool!
BTW andregarcia, where can I find your design in OSH site?
andregarcia57
zedsnotdead wrote:You know what would be really cool?
[ Image ]
or these dpdt:
[ Image ]
thanks to johnk !
https://oshpark.com/shared_projects/UwIJC5aJ
johnk
Post by johnk »
keep in mind that the staus LED on this one (and the one that I posted above) is actually reversed like this:
johnk
Post by johnk »
Visualdistortion wrote: Really great, what brand of decal and clear coat did you use? I will love finish my pedal like this.
any good clear injet decal paper will work (I used VitaCal) and then used nitro lacquer over it, shot with a spray gun.
andregarcia57
zedsnotdead
@andregarcia
have you read my message about the missing link? Havent heard from you...
There is a missing link on your PCB (OSHPark), one side of the clipping led pair is not connected to anything.
Cheers!
It's easy to overcome this, just solder a piece of wire on the back of the PCB linking 2 points, but I think I should mention it.
andregarcia57
zedsnotdead wrote:@andregarcia
Cheers!
hello ...
I think in the drive potentiometer, there really is no connection of the pins
mmolteratx
Has thanked: 93 times
Been thanked: 618 times
Post by mmolteratx »
[ Image ]
or these dpdt:
[ Image ]
I did this one a long time ago. Meant for a 1590B, but you can fit it in most enclosure sizes with a bit of cleverness.
https://oshpark.com/shared_projects/yQKC4dyx
zedsnotdead
It's not the drive pot. That pot has pin3 unconnected, like in the schematic, and it's correct.
I am talking about the led pair.
Check the red line on the following image. That's the missing link.
zedsnotdead
mmolteratx wrote: I did this one a long time ago. Meant for a 1590B, but you can fit it in most enclosure sizes with a bit of cleverness.
Brilliant!!!! :applause:
Tks a lot mmolteratx!!
