ProTone Pedals Body Rot II [traced]
- Manfred
- Has thanked: 1597 times
- Been thanked: 1301 times
I added some pads for wiring points following the shots.
PCB PCB horizontal mirrored
- Manfred
The value 43kOhm is wrong it is 430kOhms.mirosol wrote:Here. Attached.
And the pots measure:
-Distortion 100K log
-Low 50K lin
-Mid 2K lin
-High 25K lin
-Volume 50K log
I don't have any idea what that pink thing is. It reads 8n6 capacitance and 165K resistance when measured in the circuit. Bands are looking like green-green-red-black-brown.
This does have a lot in common with Krank Distortius Maximus on the topology, but it isn't 1:1 enough to call it a clone.
- Tall Steve
See, I posted my apology thinking mirosol might've had to kludge the soldering a bit to get it to work, and I didn't want to criticize his work if he did. Lord knows I've made some ugly fixes myself. If that's what they all look like off the line though, Pro Tone's giving DBA a run for their money.J0K3RX wrote:The paint or sticker or whatever that is looks good but the insides look like an 85 year old with a neurological condition soldered it for spare bingo money... And the boards look like they were etched by the same 85 year old man with a pocket knife... If I were to buy one of these and open it up (which would be the first thing I would do) I would think this must be a counterfeit! But oh no... they are all this way, everyone I have seen so far has looked like pure sh!t inside!?
Free your mind...and your ass will follow. - George Clinton
- mirosol
As my opening post says, i just bought the unit as broken and thought i'd share the guts. That's the extent i have in common with ProTone Pedals :)
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
- Manfred
I could not rest until I found information about the pink part.Manfred wrote:I had have I closer look at the pink one on the shot now, you are right, the bands are grey, grey, orange, black, braun,mirosol wrote:Well, it doesn't sound bad at all and the EQ works well. It gets amazingly close to HM-2/HM-3 territory with a design that's 1/6 in size. I would say it's a "ProTone" tonewise, not saying anything about the build quality. The low and mid pots have their lugs 1 & 3 simply soldered against each other. That's something i would never do myself...
Aren't nearly all boutique pedals like this? Slight adaptations on other designs and many with slightly or more sub-par design and build quality? I see nothing weird about that as the whole world is doing it. Some are selling TS's for $600, so ProTone Pedals are a bargain.Besides, cloning this in 1590B with a neat build would definitely have more user value than the original..
One more thing about the pink "resistor". It's daylight now and those two first bands could be grey-grey.. or blue-blue.. instead of green. If it really was just a resistor, those bands would indicate value of 8.82k. Which means that it wouldn't read 165k on a meter in any possible scenario. And that would also mean that there's no cap between 2N5088's collector and distortion control's ground.
this results in a 883 Ohms resistor with 1% tolerance. It doesn't make sense but for baffle the viewer.
What a surprise the pink one is an old axial capacitor. I found the information on this page
http://www.robotroom.com/Big-Trak-2.html
The capacitor in same shape with the Bands red, red, orange, grey, grey has a value of 22 Nanofarads,
from this it follows that the coupling capacitor has a value of 10 Nanofarads.
A had have a look at capacitor color code sheet. The fourth band stands for the tolerance, grey is not determined.
The fifth band stands fot the voltage rating, grey means 800 Volts.
- Manfred
ProTone Pedals Body Rot II is a Distortion Maximus clone with some mods and millenium bypass.
- mirosol
Huge thanks for the footwork on the cap and for drawing the schematic. I had a weird feeling about the pink thing as it looked like a resistor, acted like a cap and if it were just a resistor, there would have been a real issue with the circuit function.
I'm drawing a stripboard layout asap :) So one more time, Thanks!
- Manfred
Hugh thanks too for sharing the shots and taking the values down.mirosol wrote:Huge thanks for the footwork on the cap and for drawing the schematic. I had a weird feeling about the pink thing as it looked like a resistor, acted like a cap and if it were just a resistor, there would have been a real issue with the circuit function.
I'm drawing a stripboard layout asapSo one more time, Thanks!
- Manfred
Who owns a Body rot III pedal and could take any shots?
- mirosol
That'll deserve its own outing thread :) I'll buy one as soon as i see one for cheap enough.
If you are interested in doing the same magic to any of my other pedals, just drop me a line :) I'm running a blog on my personal collection at http://mirosol.kapsi.fi - Most of them are current production cheapos, but still..
Anyway. Back to business. Here's my stripboard layout for the Body Rot 2. It'll fit easy in 1590B with five pots. And this one won't have pot lugs soldered against each other... I tend to have two wires in a single hole if needed, so that's why the layout is as it is. Currently unverified.
[updated layout below]
- andregarcia57
There is a cut in the 100ohm resistor?mirosol wrote:That'll deserve its own outing threadI'll buy one as soon as i see one for cheap enough.
If you are interested in doing the same magic to any of my other pedals, just drop me a lineI'm running a blog on my personal collection at http://mirosol.kapsi.fi - Most of them are current production cheapos, but still..
- mirosol
Yup. My mistake. Here's the updated version.andregarcia57 wrote: There is a cut in the 100ohm resistor?
Manfred wrote:ProTone Pedals Body Rot II is a Distortion Maximus clone with some mods and millenium bypass.
So it will be correctly.
- mirosol
Thanks chriscustom for the correction. Layout updated. (if one of the moderators would be so kind to discard the previous, erroneous ones, i'd be grateful.)
- Manfred
Thanks for correcting.chriscustom wrote:Manfred wrote:ProTone Pedals Body Rot II is a Distortion Maximus clone with some mods and millenium bypass.
[ Image ]
- mirosol
Someone at our blog built my layout, so consider that verified.
- mirosol
The bass/lows pot may be a log in the original (can't confirm it at the moment as i'm ~550km away from home). One of the blog readers pointed that out after building my layout. I updated it for log taper on that pot. Good thing is that this works for sure as at least two people have already built it succesfully. Anyway. Here's the final, working and good sounding stripboard layout for this effect.
- andregarcia57
I built this pedal surprised me.
I played some time with my GT2 to clone the only thing missing was a little more bass.
hugs
hugs
- andregarcia57
one question ... can I use 1mA in volume? and 2.5k instead of 2k?
-Low 50K lin
-Mid 2.5k in place of 2kb
-High 25K lin
-Volume 1ma in place of 50ka
-Low 50K lin
-High 25K lin
- mirosol
Mid pot is fine. The volume substitution is rather big.. It will affect the frequency coming out of the tone stack. Do you have another 100K log or 50K lin? Those should be better subs...andregarcia57 wrote:one question ... can I use 1mA in volume? and 2.5k instead of 2k?
-Low 50K lin
-High 25K lin
+m
