Building A 4558 opamp from scratch.
Mrdorbe
Post by Mrdorbe »
hello guys, someone planted a bug in my head saying that guitar pedals sounds amazingly better with no opamps or chips in them and so I desided to try and build
a tube screamer with the opamp cirtuit included in the pedal circuit.
in other words I'm traying to build a 4558D opamp from scratch, now |I know that may sound very stupid, aspacialy when you can get them for less then a dollar
and it will take a lot of space and make the circuit a lot bigger.
I'm doing it from pure curiosity.
so i found the sircuit schematic and even pages that explain things but nothing about the values of the parts or the transistors types.
can anyone help me figure it out?
did anyone try this before ?
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
I've seen someone do this before but I can't for the life of me remember where, but I remember seeing a pic of a big PCB with the opamp circuit in conventional through hole components. We've probably all seen schematics for the ICs, and the 4558 isn't as complicated as some of them, but as far as values go I have no clue and unless a more complete circuit document can be found from JRC or TI (or whoever else has manufactured them) then you're in for a hell of a lot of trial and error.
As a pointer on the transistors, you can see they're all BJTs with the exception of the output which is a FET, and you can tell whether the BJTs are NPN or PNP by the direction of the emitter arrow. Apart from that you're on your own with your breadboard :mrgreen: but I will be interested in hearing how it turns out.
IvIark
Post by IvIark »
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
i think IvIark's right about doing an exact 4558D replica using the exact circuit with discrete components might be quite a task. i'm sure plenty of people have tried a discrete TS before eg
https://www.diystompboxes.com/smfforum/ ... 19.20;wap2
but that thread seems to suggest it was tricky to replicate the gain level.
J0K3RX
Has thanked: 315 times
Been thanked: 555 times
Post by J0K3RX »
Might it look something like this?
look awesome!
http://www.partsconnexion.com/t/Index/burson.php
IvIark
Post by IvIark »
That was it!! :thumbsup
commathe
Been thanked: 7 times
Post by commathe »
I find it tough to believe a discrete component op-amp will be better. You are adding in so many levels of inaccuracy and component variation that I am highly skeptical it will *imporve* performance.
That Burson discrete op-amps page made me facepalm so hard for so many reasons. It was the "let it burn in for 100 then enjoy" part that made me stop taking them seriously.
Blitz Krieg
Has thanked: 534 times
Post by Blitz Krieg »
differential amplifier with a current mirror
i think this is where most people get hung up. you won't see many values because so much depends on what's going on around it. these are "textbook" designs, but the authors don't know what your current demands are, or impedance etc.
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
Mrdorbe wrote:someone planted a bug in my head saying that guitar pedals sounds amazingly better with no opamps or chips in them
First of all, you need to distance yourself from that person. It's a stupid statement on so many levels!
If you plan on building a discrete op amp for educational purposes, go right ahead. Might want to start with some simpler design, though.
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 190 times
Been thanked: 446 times
Post by mirosol »
A single opamp would probably be more viable. But. If you want to take it up a notch from this idea, you could also discard the idea of using transistors and swap those for diodes/caps/resistors.
I think the bug in your head originally generalizes the tought. That bug may have meant that discrete JFET circuits tend to sound "better" than opamp based ones. I bet you won't get Wampler's Plexi-Drive tones with any opamp. Still i personally think that recreating a 4558 with discrete components is rather silly idea :)
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
caspercody
Has thanked: 34 times
Been thanked: 48 times
Post by caspercody »
J0K3RX
Post by J0K3RX »
jymaze
Has thanked: 86 times
Been thanked: 171 times
Post by jymaze »
A discrete opamp has not much reason to sound better than an IC. If you don't like the sound of distortion of high gain / high feedback devices, then it will sound the same to you when distorting. You should try cascaded jfets designs if you haven't tried yet (low gain / no feedback).
patafix
Post by patafix »
If I were you, I'd build a very simple disrete opamp for audio applications.
I made two of them, including the diode opamp (https://www.diystompboxes.com/analogalc ... opamp.html)which sounds quite good for distortion applications.
Patafix... so sticky
WarrenPease
Post by WarrenPease »
I agree with Patafix. There is no reason not to play around with your own discrete Op Amps. They are simple in concept, but they get really complicated when you add all the current sources and current mirrors. Leave all that out and you may create one that sounds as bad as a 4558! :D
I would start here:
https://www.passdiy.com/project/amplifiers/diy-op-amps
Download the pdf.
resynthesis
Has thanked: 41 times
Post by resynthesis »
I think it's API who use discrete opamps in their kit. Have a look at them maybe (there are loads of schematics around)
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Have a look at the schematic for the Boss BD2 pedal, it is basically using the same circuitry that an op amp is comprised of but using discrete components. I personally doubt it is worth the effort to make a discrete version of an op amp other than 'snake oil' marketing bollocks.
Here is a discrete op amp product that will also plug directly into an 8 pin DIL socket, http://www.profusionplc.com/parts/V5-OPA-D at £50 each. :secret:
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
Looking at that "Burson" discrete op-amp makes me certain that there's no fool like an Audiophool!
The transistors on a single piece of silicon are going to be extremely well matched - I would go so far as to say that they would be identical. This will also apply to the resistors in the circuit - they will be extremely precisely matched. If the components in the "Burson" effort aren't matched to within a couple of parts-per-million, the performance of their thing will be inferior to the 4558s I buy at 20 for a $1 in the Far East! Call me cynical, but I'd rather pay $0.05 for a dual op-amp than $80 for one - especially when the cheaper version will perform significantly better than the discrete copy!
Ice-9
Post by Ice-9 »
mictester wrote:Looking at that "Burson" discrete op-amp makes me certain that there's no fool like an Audiophool!
All the TI op-amps already use laser trimmed resistors and matched FETs (where used) and I expect other manufacturers op amps do as well . Discrete op amps are definite Snake oil for the HiFi brigade.
resynthesis
Yes, API discrete opamps are pretty popular in the DIY "pro-audio" community. There are also lots of others around which are simple compared to a 4558 (and probably better documented). Lots of useful stuff here, for example:
https://bgilbertsound.com/2010/03/28/di ... onal-amps/
