New builder question about BOM
Levictus
Post by Levictus »
Hi guys
New to the forum, sorta new to guitar, and new to pedal building. I do have some electronics soldering experience as I did quite a bit if diy R/C airplane stuff but not with regard to more complex circuits. My question relates to this BOM for a build I am interspersed in:
PART COUNTS
RESISTORS
(3) 1M
(6) 100K
(3) 470K
(5) 47K
(3) 1.5K
(1) 22K
(4) 10K
(1) 4.7K
(3) 3.3K
(1) 330 OHM
(1) 220K
(1) 1K
(3) 150K
(1) 6.8K
(1) 18K
(1) 47 OHM
CAPACITORS
(1) 470PF
(2) 33NF
(9) 100NF
(1) 4.7NF
(1) 100PF
(1) 47NF
(3) 220NF
(1) 22NF
(1) 1.2NF
(1) 100UF ELECTRO
(3) 22UF ELECTRO
IC'S
(3) TL072
DIODES
(4) 1N4148
(2) 1N4007
(3) 1N4733
POTS
(1) B100K
(2) A500K
(2) B10K
SWITCHES
(2) SPDT ON/OFF TOGGLES
So I understand resistances etc, but when attempting to look parts up at Mouser, for example resistors, there is also a power rating to consider. I did some research on this firum and correct me if I'm wrong, but in a 9v circuit, I should be good with a 250mW rating, correct? This pedal can also be run at 18v so would that be a bump to 500mW?
Do you see anything else in here that might present a problem or have advice with regard to any if these parts? Thanks in advance for your help.
Dave
Intripped
Has thanked: 941 times
Been thanked: 303 times
Post by Intripped »
1/4W resistors are ok for 18v pedals as well
...and welcome in the diy tunnel!
