It sounds good, except the Resonance pot which sounds strange at the extremes, but in the video of Jim Dunlop it acts OK. And Jim says that it's a mid control!
Re: Anyone has some gutshots of Way Huge Fat Sandwich?
Posted: 29 Jul 2014, 15:23
by gigelmargel
Posted: 30 Jul 2014, 17:35
by LaceSensor
Ill take some pics for you
the fet is 2n7000 FYI
Posted: 30 Jul 2014, 17:56
by LaceSensor
Posted: 30 Jul 2014, 20:46
by gigelmargel
Thank you very much LaceSensor!!! You're a fantastic man! Thank you very much!
For the MOSFET I used a 2N7000 (like in Pork Loin), so it's OK. The clipping LEDs are transparent (I didn't know that), but I don't think that's a real problem.
As I can observed from your pictures, the pin 1 of the resonance pot (marked with a blue arrow in the picture below) seems to me that is not connected directly to the ground, as the schematic says. The problem is that I can't see for sure where this pin is connected, but I think that it would be directly grounded
Anyway, I will study the pictures very carefully later.
Thanks a lot again!
Posted: 30 Jul 2014, 21:35
by LaceSensor
That is a zero ohm resistor connected to ground, so yes, it does go directly to gnd...
Posted: 31 Jul 2014, 04:49
by gigelmargel
LaceSensor wrote:That is a zero ohm resistor connected to ground, so yes, it does go directly to gnd...
Thank you very much again, LaceSensor!
In this case, I need some time to recheck the schematic around the Resonance pot...I don't have much experience in tracing
Best regards!
Posted: 31 Jul 2014, 15:55
by LaceSensor
the clipping LEDs are 3mm clear orange
they dont get very bright at all then clipping
Hope that helps
Posted: 31 Jul 2014, 20:10
by gigelmargel
LaceSensor wrote:the clipping LEDs are 3mm clear orange
Hope that helps
Any information helps...I will replace the LEDs as soon as I will buy some orange clear 3mm, but I think that it's not a problem.
The main problem remains the Resonance pot...it acts strange (one sound until 7-8 o'clock, another tone from 9 to 15-16 o'clock and the third tone over 16 o'clock), but I think that's the way it works...in the demo I saw that it sounds almost like my clone
Anyway, I will recheck the schematic from your images, but it's hard for me...but that's the way I will learn to trace from photos
Best regards!
Posted: 31 Jul 2014, 22:19
by LaceSensor
hi
the way you describe the pot is how mine works, pretty much.
two different sounds at either extreme CW and CCW, then a lot of similar sound for most of the actual travel of the pot.
im not that inspired by it!
Posted: 31 Jul 2014, 22:23
by gigelmargel
Hi, LaceSensor!
It's clear for me now that's the way in which the Resonance pot works. I like very much the Pork Loin, so I hoped that the Fat Sandwich is so good, too.
Anyway, if you want, we can try to make a trade
Best regards and many thanks!
Posted: 01 Aug 2014, 09:52
by LaceSensor
~Ive got most of the way huge pedals
the fat sandwich is ok, just the resonance pot I dont really feel its that great.
Posted: 01 Aug 2014, 13:53
by gigelmargel
LaceSensor wrote:~Ive got most of the way huge pedals
Yes, you're right LaceSensor
I like very much their pedals too...I think that Pork Loin it's a fabulous overdrive, while Ring Worm and Supa Puss are on my wish list from a long time
Thank you very much again!
Posted: 01 Aug 2014, 16:38
by LaceSensor
the ring worm isnt true bypass and bleeds but its fun
supa puss is a good analog tap delay, modulation on it is excellent
Posted: 01 Aug 2014, 20:35
by coldcraft
i produced the original traced schematic of the Fat Sandwich, and yeah the resonance pot is a little funny. I love the FS so much that I then picked up the Pork Loin. I find the PL is trickier to dial in, mostly because of the mixing of the two paths.
Posted: 01 Aug 2014, 20:50
by gigelmargel
coldcraft wrote:i produced the original traced schematic of the Fat Sandwich, and yeah the resonance pot is a little funny. I love the FS so much that I then picked up the Pork Loin. I find the PL is trickier to dial in, mostly because of the mixing of the two paths.
Thank you coldcraft for your tracing!
Re: Way Huge - Fat Sandwich
Posted: 12 Jun 2015, 06:33
by fusionid
Hey guys,
finding the gain too compressed and the high end too biting. Has anyone done some mods that would recommend to this pedal??
i think I would be interested in putting in a switch to take off 2nd stage from the circuit. Perhaps replacing the diodes?
Posted: 14 Jun 2015, 13:08
by modman
fusionid wrote:i think I would be interested in putting in a switch to take off 2nd stage from the circuit. Perhaps replacing the diodes?
What are you waiting for? Approval? Just experiment... by taking out R11 (removing hard clipping diodes)
Posted: 15 Jun 2015, 05:06
by fusionid
hmm no
guidance.
I took a look at the schematic and I have some ideas
