Lovetone - Meatball  [traced]
The schematic used to be at moosapotamus.net, but now gone. Only two projects based on the schematic survived:
http://home.planet.nl/~joep.remkes/mcmeat.html
http://pisotones.com/Meatball/psst/meatball-psst.html
Did someone save the schemo?
McMeat.pdf
McMeat, Meatball workalike by Joep Remkes
(240.59 KiB) Downloaded 335 times
p.eat
Has thanked: 50 times
Post by p.eat »
anybody have some gutshots of an original? I'd like to have a look at the layout.
thanks,
Peter
the tourist
Post by the tourist »
You can see the solder side here - http://filters.muziq.be/model/lovetone/meatball
puppiesonacid
Been thanked: 12 times
Post by puppiesonacid »
any confirmed builds from the McMeat pdf yet?
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
puppiesonacid wrote:any confirmed builds from the McMeat pdf yet?
Yes, I build one...... nice project!
lohstah
Has thanked: 214 times
Been thanked: 96 times
Post by lohstah »
yep, cool project, xspecially for bass players. i actually built mine before i started etching, so i perfed it.
cheers,
lohstah
I'm into cool bass effects. What does it do exactly?
puppiesonacid
Sure has alot of freakin' knobs!
Alex Frias
Been thanked: 14 times
Post by Alex Frias »
I built a McMeat two years ago. A monster of a filter! Very pleased with the results.
I also did some mod's but I don't remember exactly how they was done, one made the "Color" control much more responsive along the way. The other was about to add the Tremulus Lune LFO to the center frequency of the filter, kind of cycling wahwah.
I didn't use the proper already made optocouplers, so I did them with LED + LDR covered with some thermo-retractil tube.
The looping chain is a very useful thing too as you can use some dynamics-killing effect (like a fuzz or a compressor) and the McMeat envelope detector will follow the unprocessed signal envelope.
I think there was an error or two on Pisotones site regarding one rotary switch wiring and a resistor that was forgotten in the detection section. aside this, it's a marvellous tutorial.
alteredsounds
Post by alteredsounds »
Quite looking forward to building this, a change from overdrive and fuzz overkill! Do you know if the errors you mentioned are corrected in the mcmeat.pdf attatchment on this thread?
MarcoMike
Post by MarcoMike »
no mistakes on the pdf. I built it from that project and works great!
Bernardduur
MarcoMike wrote:no mistakes on the pdf. I built it from that project and works great!
+1
Some of the components aren't mounted on the PCB though; maybe that was the "error"
Alex Frias
As MarcoMike said: you can follow the .pdf with no fear!
I think the attention must be on the off wiring and remember that some components are not PCB mounted.
IMHO, this project worthes all the effort.
rs
Has thanked: 95 times
Been thanked: 7 times
Post by rs »
I've built mine per the PDF and it worked out very well.
It's a very cool project 8) .
fish head
Post by fish head »
To those of you who've built the McMeat: what kind of enclosure did you use?
the tourist
I used smallbear's DD size - http://www.smallbearelec.com/Detail.bok?no=52
in hindsight, I think I probably could have squeezed everything into a smmh/holy stain sized box
rs
Post by rs »
I've built my own with bended alluminum.
jazzercountry
Post by jazzercountry »
I think I'm going to use toggle switches instead of the Lovetone's rotaries. (Got the idea here: http://www.martoneaudio.com/meatwad.htm) Anyone know what type to get? I know there are 2 with 3 positions and 2 with 2 positions, I just don't know if I need SP3T & SPDT or what. Also, one of the build reports I saw had some caps across some of the poles of the range knob, wasn't sure if I was seeing that correctly or how to apply that to a toggle switch. Said picture is here: http://www.pisotones.com/Meatball/psst/ ... edium.jpeg
Thanks much!
Ryan
theyear2042
Post by theyear2042 »
i built mine into a 1590bb - had to leave off the true bypass switch due to lack of room
imo the pedal is way overcomplicated and difficult to use. imo you would be much better off making the MuTron III - RG did a pcb for it - same sound, much better control.
2042!
