Lovetone - Meatball [traced]
- Alex Frias
I think both represents two sides of the coin, if you prefer simplicity, go for the Mutron, but if you like to dig a bit more, the MacMeat is the thing, IMHO. It gets a little time to be confortably using its capabilities. I even added a LFO and a TE P.W.M. circuit before the loop. It delivers, man! I call it "McMeetMyballs".
Hi everyone,
I'm ready to start the offboard wiring now, the board's all ready, but I'm trying to see if there's any demand for a corrected/easier to read wiring layout for this project? I know that pisotones is the only one out there, but there are errors in addition to the fact that it is rather hard to distinguish some of the wires. If we could get something similar to the ringstinger/stringringer project for this one, I think that would be a great resource. I'm a little unsure on following the schematic, so I would need a little coaching - but I don't mind drawing it up if no one else wants to take that on.
Thanks so much!
Thanks so much!
you guys have me totally jazzed about building this thing!
¿Errors?jazzercountry wrote:...I know that pisotones is the only one out there, but there are errors...
I'm the guy responsible of http://www.pisotones.com and AFAIK there are no errors in that project... Several people built Meatballs without problems
Well, I'm going off of hearsay with that. If there is any way you can help me out with color coding some of the wiring, I think it might clear up any confusion.Calambres wrote:¿Errors?jazzercountry wrote:...I know that pisotones is the only one out there, but there are errors...
Well, that project was a collaboration from my friend psst. I'll try to clarify your questions. What colours do you have problems with?
The rotary switches are simple 4P3T.
http://www.alliedelec.com/Search/Produc ... A40315RNZQ
- Duckman
- Opamp Operator
Searching about the meatball I found this thread and I hope this little corrections (according with mcmeat schemo) can help for next visitors.
Hat off to Pisotones, one of the very few pages in spanish with a lot of very well explained stuff... nadie es perfecto, no?
- marmora
- Completed builds: Distortion +
EA Tremolo
Weird Sound Generator
Mingrod
Honeytone speaker out mod
Line 6 DL4 and MM4 mods
Boss AC-2 clone
Sparkleboost
BSIAB II
Lofo Mofo
Jawari
Psychtar
CMOS Nyquist Aliaser
Paralooper
Punch-In-The-Face
Gargletron
Omni Drive
Blue Magic
Boss SG-1 clone
Parapedal
Feedback Looper
PEEPlug
ST-C Delay
Casio PT-100 bends
Riot Zone
HT8950A modulator
Blast Fed Disaster
Crushed Glass
Mac Oscilloscope
Gristleizer
Atari Punk Console
Dub Siren
UM3561 Siren
Bent Radio Shack Playtime Keyboard
Bent Animal Band Keyboard
Bent Barbie Karaoke
Rebote 2
PWM
Distortus Maximus
Woolly Mammoth
Phase 45
Dr Boogie
Femtoverb
Random Number Generator
Mayhem!
Uglyface
Bent Casio SA-40
Clari(not) Cubed
Black Toast
May Queen
Bent Speak and Read/Math
Thing Modulator
Geofex Low Fidelity/Noise/Telephone
Lovepedal Woodrow
Bazz Fuss
Bent Vtech Alphabet Desk
Bent Realistic Rap-Master
Noise Box (modded Lofomofo, Noise Ensemble, Dirty Sanchez)
Robobuddy - Location: Chicago
- Has thanked: 1 time
- Been thanked: 4 times
- Contact:
In regards to jazzercountry and others that want to use toggles instead of rotaries. It seems you can use an on/off/on SPDT for SW1, the bandwidth switch.
I'm wondering if you can use a 3PDT toggle for SW2, the sweep control. Can anyone verify if it will work? It seems it would work. Thanks!
marmora wrote:In regards to jazzercountry and others that want to use toggles instead of rotaries. It seems you can use an on/off/on SPDT for SW1, the bandwidth switch.
Yes, it works.
I built mine with this switch combination:
1x on/off/on SPDT for SW1 (Bandwith)
1x on/on 3PDT for SW2 (Sweep)
1x on/on DPDT + 1x on/on 4DPT for SW3 (Range)
2x on/on SPDT for SW4 (Mode)
- gilmour_pugliese
some news for us?ryanuk wrote:I was working up a project based on the original PCB layout (with switches mounted to the PCB) - saves bakin your noodle over the wiring for the mcmeat project.
However, someone on the "other" forum beat me to it.
If you wanna build a meatball I would advise to search over there as you'll have a higher probability of success.
RyUK
- LaceSensor
Id recommend the Meatsphere by Taylor at musicpcb.com
- pedalgrinder
this project would be nice to have the pots so they can be soldered onto the board even switches would be good to to cut down the wiring bonanza thats involved. Nice project though.
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
http://musicpcb.com/pcbs/meat-sphere/gilmour_pugliese wrote:some news for us?ryanuk wrote: If you wanna build a meatball I would advise to search over there as you'll have a higher probability of success.
RyUK
https://www.diystompboxes.com/smfforum/ ... ic=92894.0
- pedalgrinder
sensational i didn't know you could buy a board for that one thanks for posting that your a legend.
- gilmour_pugliese
Nocentelli wrote:http://musicpcb.com/pcbs/meat-sphere/gilmour_pugliese wrote:some news for us?ryanuk wrote: If you wanna build a meatball I would advise to search over there as you'll have a higher probability of success.
RyUK
thank you man, thank you to all
- gilmour_pugliese
Hey Lace, would you like to share with us your graphic?LaceSensor wrote:Id recommend the Meatsphere by Taylor at musicpcb.com
https://i1178.photobucket.com/albums/x3 ... 020260.jpg
thank you
