Is the mode switch 1, 2, 5 & 6 in the middle position, or 2, 3, 4 & 5?
Assuming conventional
1 4
2 5
3 6.
pin identification?
Lovetone - Meatball [traced]
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
There are two types of DPDT on-on-on, the diagram uses type 1 (the most common version):
...so 1+2, 5+6
- Paul_5
OK. still dipping in and out of this project. All of my controls seem to be doing what they should - they change the sound and filter off frequencies that I would expect, but I don't have any sweep - the LEDs light up whenever they are triggered, so I'm assuming that the 1458 is doing what it should, but there isn't any sweep in either direction, almost like. fixed wah pedal. Any clue where I should look next?
The sounds in my head don't match the sounds from my amp, I guess that's why I'm here...
