Footswitch explained
mouthdakota
Post by mouthdakota »
I have some extra 3pdt switches. Can anyone help me connect one to turn off/on my dying battery simulator? http://beavisaudio.com/Projects/DBS/
karul
Has thanked: 539 times
Been thanked: 244 times
Post by karul »
You don't need a 3pdt switch for that. A SPDT will be sufficient.
DBS - dead battery simulator
DBS - on
DBS - on
dbs switch.JPG (16.09 KiB) Viewed 3223 times
mouthdakota
I know-but I want to use what I have here right now.
teemuk
Been thanked: 55 times
Post by teemuk »
Uh, then you just use one third of the switch and leave the other 2/3 disconnected.
mouthdakota
Do i wire it to the pot or the dc jacks, or both?
karul
Post by karul »
it's simple: use 1/3 of the switch
3PDT is (almost) like three SPDT switches connected together in one package.
more reading:
http://beavisaudio.com/techpages/Switches/
dbs 3.jpg (15 KiB) Viewed 3214 times
karul
Post by karul »
like this
P.S. be careful, that schematic from beavis's site is showing center positive dc jacks
karul
Post by karul »
center negative dc jacks wiring
mouthdakota
Thanks all. Works good.
