Rubber feet just... fall off
I've done dozens of builds now, but one thing I still can't do well at all is getting rubber feet to actually stick to the bottom of my enclosures. After I paint and clear coat, I usually attach the little transparent feet that are designed as bumpers, but they always fall off. What do you guys do for feet?
- Crowella
- Degoop Doctor
I've had no issue with using the 3M adhesive brand feet, even after finishing. I'd say add a tiny bit of epoxy and/or gently scuff up the area where you are putting the feet just to give the adhesive more to hold onto. Hmm...
- Duckman
- Opamp Operator
Same here... 3M is the thing and not a problem 'till today.
But -and at risk of being obvious- consider that if you or somebody else will use Velcro at the bottom, rubber feets are a waste.
- tonyharker
Super (Crazy) glue ??
- FiveseveN
There are rubber feet that are designed to be attached with screws, which can be the same screws that keep the lid on, though may need to be a bit longer than the ones that come with the box. For Velcro users and such they are easy to remove.
Kind of like these, but smaller: http://mouser.com/ProductDetail/Hammond ... x8wl25EjQD
- ljn
- my favorite amplifier: Sears 125 xl, Kasino U100-P
- Completed builds: Fuzzrite (Si and Ge versions) , univibe, companion fuzz, fuzz face(si version), FY-6 super fuzz, FZ-1S, Scrambler, Tone Bender MkI (nearly complete). I have modded my vox v847,Seymour Duncan tweak fuzz, my bass and my guitar ( slightly).
- Has thanked: 7 times
- Been thanked: 7 times
If you really intend for them to stay on, the yes. Super glue works great. I used some for my fuzzrite clone. For the actual rubber feet, I cut four little square pieces of rubber that I found in an old radio. They haven't came loose yet.tonyharker wrote:Super (Crazy) glue ??
Education is 10% knowledge and 90% brainwashing. We're only told what they want us to know. The rest is fabrication in it's purest form.
