electronic parts in garage during winter
jimiguitar
Post by jimiguitar »
is it safe to keep electronic parts in garage during winter ? or how cold can you keep them before they are ruined
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
jimiguitar wrote:is it safe to keep electronic parts in garage during winter ? or how cold can you keep them before they are ruined
That would usually be specified in the component datasheet. How cold does your garage get?
jimiguitar
looks like i'am safe all of the data sheets so far that i saw say -55c which is about -65f it dont get colder than single digits at the worst winters we had
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
I would be more worried about condensation causing corrosion than the actual temperature.
I know condensation in my garage can be pretty bad when the temperature changes rapidly.
Duckman
Has thanked: 320 times
Post by Duckman »
deltafred wrote:I would be more worried about condensation causing corrosion than the actual temperature.
I agree. Unless you live near the Poles or in some very extreme climatic condition, you must concern more about how humidity work in metal parts of components, than temperature.
Soldering doesn't like oxidation. :secret:
