biasing jfets taking meters impedance in account
jimiguitar
Post by jimiguitar »
when measuring jfets for biasing do i need to take my meters impedance 10 meg into account and add that to the circuit
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
jimiguitar wrote:when measuring jfets for biasing do i need to take my meters impedance 10 meg into account and add that to the circuit
If you're measuring the transistors in-circuit, i would say no. Unless your bias network introduces an impedance large enough to make the extra 10M in parallel significant ;)
jimiguitar
thank you for the the reply i got confused i thought my meter might be effecting it but it depands were your meter probes measure where where your negative and positave they get 2 different readings that depends
