I'm not shure if this is the right place for this pedal, as it is not boutique, but it was gooped so anyways...
I had this laying around for some time now and thought I'd better post it as is before it gets lost in my pile of layziness
So, sorry for the scibbling but it should be good enough for a curious look.
I find this interesting as there are no clipping diodes on the board, even though it's an opamp circuit.
-The opamps are U1: JRC074, U2:TLC2264C
-Caps are not labled
-the strange gainpot is a fourpin, the fourth tapped off at the middle between cw and ccw, numbers around it show the resistance
measured at the extreme settings. I don't know if it makes much sense but was the best I could get
-skipped the led circuit (including some low voltage indication) and the bypass switching (millenium).
