BAJA Silent Selector
irmcdermott
Has thanked: 18 times
Been thanked: 21 times
Post by irmcdermott »
so i etched my board last night and then noticed that the jacks I got from smallbear are too big and the dc jack is too small to mount. which ones did you all use to mount them to the board?
the IC fits, so i know i didn't print it at the wrong resolution or anything like that.
irmcdermott
Barcode
Been thanked: 32 times
Post by Barcode »
irmcdermott wrote:so i etched my board last night and then noticed that the jacks I got from smallbear are too big and the dc jack is too small to mount. which ones did you all use to mount them to the board?
I didn't mount mine, I usually don't. I wired them offboard.
the jacks used are Neutrik type NRJ6HF-1 or NRJ4HF-1 (just cut the ring contacts if you use the 6 pin variety)
irmcdermott
finally got around to finishing this one, and it works great! totally noiseless, great design. thanks for all of your contributions! up next, the Baja Small Clone!
DimebuGG
Been thanked: 198 times
Post by DimebuGG »
Baja,
If I'll use this circuit at 15V, any changes to be done?.
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
DimebuGG wrote:If I'll use this circuit at 15V, any changes to be done?.
Maybe a heatsink on the voltage regulator ?
DimebuGG
Post by DimebuGG »
I mean i'll be using the +15V regulated supply thru out the whole circuit.
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Post by JiM »
DimebuGG wrote:I mean i'll be using the +15V regulated supply thru out the whole circuit.
The CMOS gates will withstand 15V without problem (just increased power consumption), but the current limiting resistor of each LED will have to be scaled.
hbo
Has thanked: 28 times
Been thanked: 196 times
Post by hbo »
Hi, Baja. First off, thanks for an excellent project.
I built this on vero last night (my own layout based on your schematic) and it didn't quite work as expected. After comparing your PCB layout to your schematic I noticed what I assume is a mistake on the schematic (the PCB layout seems correct based on the build reports here); one inverter (pin 8, 9) seems to have been drawn at the wrong location.
Given the CMOS logic involved here I'm guessing this inverter would throw things a bit off (explaining why my build didn't quite work). Is the schematic wrong or am I just seeing things?
hbo
Post by hbo »
I did a new vero build last night trying out the schematic update in my previous post, and it now works. I think the original schematic should be updated.
And here's my working vero layout.
good spotting Harald and yes you are correct - my schematic has an error :oops:
here is the corrected schematic
rosetta
Post by rosetta »
does the old PCB work with this new schem???
the old PCB is correct (the old scheme was incorrect) - okay :roll: :wink: :wink:
Nick123
Been thanked: 9 times
Post by Nick123 »
Great project and surely the next one for me.
I know that it should be noiseless but is there
any noticeable tone sucking ?
not that I have heard :wink:
Baja Silent Selector.jpg (65.41 KiB) Viewed 1939 times
Baja Silent Selector Switch 090220.zip
(22.72 KiB) Downloaded 86 times
updated artwork etc with gerber files :wink:
I used multilayer ceramic capacitors for the 2u2 and 1u capacitors - (you can still use aluminium electros if you want to though i prefer to use the MLCC these days)
