one ge sounded incredible, better than all the rest. imagine my surprise when i had mis-sorted, and the "pnp germanium" ended up being an NPN germanium...
ac176 to the rescue, yo.
changes from old juerg
harmonics pot now 1 meg, raised from 100k. input lug is wiper (pin 2) rather than pin 3 as before. big difference.
ground unused lug of perc pot. (lug 3)
output volume pot raised to 100k rather than 50k.
power supply 9.79vdc
q1 ac 176 npn
hfe 95
uf 119mv
c 2.01v
b 1.94v
e 8.42v
q2 bc550 npn
hfe 415
uf 699mv
c 9.05v
b 8.50v (drops from there all the way to zero as the 47u cap discharges.. that cap is the key thing in this )
e 8.48v
stupid pedal trick imminent of course...
i think i got this right... will try and draw a proper schematic tomorrow.
works much better than the previous version... go figure.
the layout on tagboardeffects will work.... just swap out the two pots and add the ge npn as q1.
i damn near went crazy trying transistors in this... that cap make shit nuts!! if i pulled the pnp, i got a much better signal... at first... clear and loud and harmonic... til the cap began to discharge, at which point it would de-percolate.
people with issues trying to get this circuit up, power down between transistor swaps, and short that cap or it will make you fucking CRAZY.
FWIW, every 176 i tried worked. none of the pnp's i had, ge or si sounded as good. <shrugs>
a REAL high gain darlington may be worth trying in q2. q1 seems to wanna see around 100 if npn, and 50 or so if pnp.
this is the weirdest circuit on the planet. <smh>
