Since that time, the price of MN3005s has skyrocketed!
MN3008s can still be sourced for a reasonable price..so...I decided to explore the AD-900 MN3008 version.
Using soulsonic's schematic from this thread, viewtopic.php?f=1&t=7356 I figured out the differences between the two versions by studying component side images of the MN3008 version. I was able to produce a schematic..but wanted to verify the drawing before I posted it.
I made a request in "I'd like to see the guts of" thread, for any trace side images, and Dirk Hendrik was gracious enough to provide trace side images...and more! Thanks again Dirk!
With the info that Dirk provided, I was able to verify the schematic. (The circuit was correct but I had some of the component numbering wrong)
Dirk also provided an overlay (silk layer) that I took the liberty of adding component designations to, and the trace side art which was unfinished. (There were a few areas that were highlighted in red that the "artist" was unsure about)
I also took the liberty to fix these "problem" areas.
I'm not sure who put together the silk layer and trace side art but...credit and thanks go out to you!
I have PDF files of all of the above. If needed...please request. Also...if there are any talented forum members out there that are good at resizing the trace side board image while keeping high resolution...I have a large BMP file if needed.
