New PCBs: ST-9 Super Tube Screamer, MT-10 Mostortion, OD-880
Posted: 14 Feb 2015, 15:26
by aionios
A few new Aion projects for Valentine's Day...
Cirrus (Ibanez ST-9 Super Tube Screamer): extremely rare TS variant with parametric midrange boost. Onboard clipping diode switch. Uses jumpers to select ST-9 (boost before clipping) or STL (boost after clipping) variants.
Quantum (Ibanez MT-10 Mostortion): early 90's distortion/OD in the Ibanez "10 series". TS-style clipping followed by a 3-band tonestack, plus a unique MOSFET op-amp.
Quark (Maxon OD-880 Overdrive/Soft Distortion): Maxon's answer to the MXR Distortion+, halfway between a Dist+ and a Boss OD-1. Includes onboard bass and clipping diode switches.
The Micro 3PDTs are now available in yellow as well, so you can now get a 3PDT board to match any project. $12 each.
Also, if you missed it, last month I released the Fractal (Pearl OD-05), Aurora (Ross/Dyna Comp) and Lumin (BBE Sonic Stomp).
