Runoffgroove - Thunderbird Preamp
rcustoms
Has thanked: 363 times
Been thanked: 518 times
Post by rcustoms »
Hey guys what do you think about this design by runoffgroove group?
see the original page
http://www.runoffgroove.com/thunderbird.html
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Post by rcustoms »
ok looks awesome
do it one
schematics first rev.
rcustoms
Post by rcustoms »
i do my homework
schematics corrected
The attachment schema.jpg is no longer available
layout
The attachment ALL.jpg is no longer available
parts
I intend to add a solid stage 100 watts power amp, and hear how good it really.
rcustoms
Post by rcustoms »
sorry, pcb without jumpers
B Tremblay
Been thanked: 14 times
Post by B Tremblay »
It's nice to see interest in our work.
However, I'm a bit confused why there is a need to redraw the schematic and share it publicly with no attribution to runoffgroove.com when a link to the project page was provided. The project page contains a link to purchase a high-quality multi-layer PCB and we provided a compact PCB layout for those builders who etch their own boards. Next, a layout with a new name for the circuit (and still no credit to runoffgroove.com) is shared.
Am I missing something here?
B Tremblay
runoffgroove.com
rcustoms
Post by rcustoms »
B Tremblay wrote:It's nice to see interest in our work.
i do not pretend at anytime take your design and claim that is mine ,when i open this topic i put the real schematic from your site and with your business name but someone(moderator) i think ,erase this schem maybe for your own safety.
I really like the work done by the people at runoffgroove ,and the only way that i find to share with the fsb guys was redraw the schematic and do a pcb for use like a preamp style.maybe someone contribute to mod your design or explain your new amp emulating system.
I apologize if I have offended anyone,my only intension was to show everyone your awesome design.
sorry for my english
B Tremblay
Thank you for explaining. I was hopeful that your intention was positive. Would you please add the circuit name and appropriate credit to runoffgroove.com on your images?
B Tremblay
runoffgroove.com
rcustoms
Post by rcustoms »
B Tremblay wrote:Thank you for explaining. I was hopeful that your intention was positive. Would you please add the circuit name and appropriate credit to runoffgroove.com on your images?
Here
The G
Grease Monkey
Has thanked: 407 times
Been thanked: 282 times
Post by The G »
@rcustoms, you could go to User Control Panel > Manage attachments and delete the non-copyrighted images.
rcustoms
Post by rcustoms »
ggedamed wrote:@rcustoms, you could go to User Control Panel > Manage attachments and delete the non-copyrighted images.
thanks.
is done
FuzzMonkey
Has thanked: 43 times
Been thanked: 26 times
Post by FuzzMonkey »
Mr. Tremblay,
Purely out of interest can I ask why the 24 volt power supply instead of a +/- 12 volt dual supply with the Thunderbird?
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
Perhaps because you can get 24V from a cheap SMPS for laptops etc.
obvious really - he is designing for use from 9v dc :roll:
FuzzMonkey
Using the LT1054 you can double both the positive and negative sides of the power supply.
from a single 9v dc battery ?
FuzzMonkey
Yes. Tried and tested using the schmatic below as seen on page 11 of the LT1054 datasheet. This method also works http://goo.gl/3FGBkU. Used both with methods using Schottky diodes and voltage regulators when playing around with a Carl Martin Plexitone on the breadboard to archive the original's +12 / -12 power supply.
papasteack
Post by papasteack »
Thanks for pointing at it !!!
The dynamics effect remember me a bit the ampeg (crate) tube patent used for the ampeg vh140c in it explanation.
But ampeg's stuff is implemented inside the feedback loop, and it can raise a reallyyy heavy distortion...
Really interesting to see debucked implicitly this part of the origin of tube amp non-linear dynamic ^^
Seeing this, its really time to learn how to do simulations ^^
THANKS RUNOFFGROOVE !
