Note: You need Sprint Layout 6 drawing program to view and edit it.
C25 İncreased to 560p, done and thanks for noticing itbajaman wrote:C16 is unnecessary - leave it out or just increase C25 to 560p
İ think it's correct now, thanks for the informationJ0K3RX wrote:On your Sprint layout C22/500p is shorted... Should go to the other side of the trimpot. :wink
C28 positive lead is connected to the negative lead of C26, - C26+ and C28+ should be connected
İ changed the pcb as you suggestedapollomusicservice wrote:I would have suggested some minor changes on pcb.
i did't put that on purpose, i don't need that "pull-down" resistor to eliminate pops, i use that resistor on my switch boardpeterc wrote:Abakuzam
R1 (1Meg) on the input seems to be missing?
Peter
are you not someone?fuzz_germanium wrote:Someone could build it?![]()
video?
