Fender Fuzz Wah volume pedal [schematic]
Posted: 20 Nov 2013, 00:09
by pinkjimiphoton
i had one of these, and REALLY dug the fuzz, and had asked if anyone could help me convert the fender fuzz wah circuit to just a fuzz...
gus smalley posted this:
which led to this:
it's even verified... i'd tried a similar layout a while back, but made 2 rookie mistakes.. was missing the 10k resistor going to the + input of the chip, and had b+ going to pin 8, not pin 7. :icon_redface:
so anyways, now it's built and verified.
how's it sound? i REALLY like it. very thick buzzy sustaining distortion, with a buffered clean that can be blended in.
you can use a 5089 or whatever, but i advise to socket the tranny and try a bunch of npn's. to me, it sounded best with an npn ge, REVERSE beta'd. figure that one out.
but to my ear, that was the best fuzztone, and the best balance between clean (slightly boosted) and fuzz (seriously fuzzy!!) with the mix pot.
i also added a simple tone pot. i know, big muff or swtc, but i like the way this one sounds better, and it's bonehead simple. a pot and a cap. notice the input to the tone cct is to the wiper... this seemed to also sound better than with output from wiper.
any dang single OA will work fine... 741, 5534,tl061/71 were all tried.
also tried some fets and jfets. if you want a really killer tube like fuzz, try a j201 or similar!! the clean blend kinda sucks with them, but MAN!!
nice, i mean NICE distortion.
anyways... i really diggit... thanks gus once again for helping me out, and if you guys build this, please let me know..
stupid pedal trick will happen eventually. playing too damn much.
Re: cbs era ic fender fuzz from fuzz wah w/vero
Posted: 20 Nov 2013, 01:53
by bootle
cheers jimi!
will whip it up on the breadboard tomorrow.
is all the stuff in Gus' schem stock parts and value?
maybe you have the original fuzz wah schematic?
Posted: 20 Nov 2013, 03:06
by pinkjimiphoton
original caps were 22u apparently.
u used 47u's, and a 100u for the big one. 10u output.
the chip was an earlly *558 variant. since this doesn't use the wah, a 741 is sufficient.
really phat sounding.
mark hammer said if ya added diodes at c1 and c2 you can get octaves out of it. just a thought.
i used bat47 and 1n60 shotke (i don't think it's ge) for clipping.
Posted: 07 Dec 2013, 03:59
by CHEEZOR
Thanks for the schematic. Just helped me fix one I got from ebay.
Posted: 07 Dec 2013, 18:08
by pinkjimiphoton
i almost bid on that one. i really like these suckers.
try a 5532 for the opamp... same fuzz, but a little less noise.
Fender Fuzz/Wah/Swell IC Version Guts
Posted: 29 Mar 2015, 05:33
by absolutelyfibulous
Re: Fender Fuzz/Wah/Swell IC Version Guts
Posted: 29 Mar 2015, 15:51
by armdnrdy1
Thanks for posting.
Look at the size of those .1µf caps! There must have been a "sale" on 200 volt caps that week!
If Fender actually manufactured this, the caps would have been taken from their amplifier parts stock I would imagine.
Posted: 29 Mar 2015, 16:42
by sinner
Sprague e-caps are replacements
Could you take direct pcb shot for me with dimensions?
Posted: 30 Mar 2015, 03:51
I thought the Sprague's looked out of place in there. I haven't seen other pictures of this circuit so I just had their shiny new look and the bit of flix residue on the board to go off of. Also whoever did that also disconnected the power supply jack for whatever reason.
The non electrolytic caps look exactly like the ones I ripped out of my early 70's Bassman 10 so that's a very fair assumtion.
And I will grab my tape measure from work tonight and take a better picture in the sunlight tomorrow when I get home.
Posted: 30 Mar 2015, 07:14
by sinner
Cheers mate. I'm after reworking the board and doing full layout for that. This is why I need it. If you could do whole board and close ups that would be great. Plus the wiring
30D's are my favourite axial caps
Posted: 30 Mar 2015, 07:37
by lolbou
sinner wrote:Could you take direct pcb shot for me with dimensions?
Some GIMPing and Inkscaping gives this picture and an estimated 95 x 79 mm board size.
- image3049.png (428.41 KiB) Viewed 2944 times
I used the 741 pads to adjust the pic to a proper 0.1" grid. Hope this helps!
Posted: 30 Mar 2015, 07:58
by sinner
It does help. Thanks a million
Re: Fender Fuzz Wah volume pedal
Posted: 01 Apr 2015, 14:32
Posted: 01 Apr 2015, 15:03
by sinner
No rush mate. Thanks for all you did already
I'm finishing one project this week and i have another one in works but I try to do as much as possible during next week
I will have few questions more likely so I hope you stick around ; )
Posted: 01 Apr 2015, 15:48
I like this little corner of the net. Never had anything to contribute really except for now and to thank you for that excellent Tonebender layout you did. I figure if I have something and it's not already here then I should add it to the mix.
I tend to gift or lose a lot of pedals but I see this Fender sticking around for a long while so whenever you have questions I'll pop it open and see what I can answer. As far as I know the only thing missing on the wiring is the power jack. Not entirely sure why it was removed. It's the Electro Harmonix style 1/8 inch jack and those adaptors aren't exactly hard to find. Every Voodoo power brick or something similar comes with one. Oh well.
Posted: 01 Apr 2015, 17:36
by sinner
I'm happy you like my work
Whatever you have there - bring it on. As long as it's old and/or out of proportion
My new website is scheduled to be rebuild (sort of) 1st of May so I'm after new content
Posted: 05 Nov 2015, 13:53
by Blend
Here is a picture of the original transistor that, combined with the replacement of the CA3458 with an MC1458 ("modern" version without breath background), it maintains a sound fuzzy. With other combinations opamp-transistor-led-diodes you can go on territories of distortion.
